The choke is installed with an electric conversion, and the choke housing hot air port is plugged. I think the fuel bowl is empty at first. My fast idle is set low. I use my foot to warm it up and then I can drive around without the fast idle bothering me too much. My wife is doing the startup in the video, so she just starts it and then it is idling at maybe 500rpm - once warm and off fast-idle it idles at 550~650rpm.
It takes forever to come off fast idle. Earlier, I tried a hot choke setting so the idle would drop sooner, but the choke plate is open too far at cold so it is hard to start. I set it back to a colder setting but even then, the choke plate looks like it is open to much. Right now it is hard to start because A) the fuel bowl is empty, or B) the choke is open too far, or C) both the fuel is empty and the choke is open too far. I don't want to mess with bending the choke rod to adjust the plate until I know the hard start is due to the choke opening and not that there just isn't any fuel. I need to test for both.
I borrowed this mage from repairguide.autozone.com
Here is a link to fast idle adjustment on youtube by WhoSaidTyler
https://www.youtube.com/watch?v=yX_hCujFQ_I
Another youtube here by TheYoshiClan on fast idle won't kickdown
https://www.youtube.com/watch?v=XY_U5n52Oec
Here is my K5 startup from cold - I think it was sitting for five days before this.
[youtube]https://youtu.be/3mkL-wpzTyg[/youtube]
My best guess was that I had the electric choke connected to the old distributor 10v source - so it was slow to open. I checked and it has 12.5v. I still like the idea given in an earlier post to connect to the hot lead to the alternator - later I will give that a try.
After this video, I sprayed some WD-40 behind the choke housing, the movement of the weight seemed stiff. I think it helped allow the choke to open. The next step are A) check for fuel and B) cover choke w/ hand and see if it starts better. If B, then bend the choke rod. If A, I don't know.
The attached picture is idle at warmup. It is about 160 deg F and idling at 800rpm.
If you have any advice and just know what the problem is based on what I have posted here - I appreciate it if you share your knowledge so I don't have to go try the 'how bout this, bout that' game.
