454Sub
5/8 ton status
Im fairly certain on them style ALTs, you need an idiot light on the "exciter" wire to get it to charge correctly below a certain RPM. I know I read/heard/seen/imagined that somewhere.
Unless you're looking to set your engine compartment on fire I wouldn't do that. Notice what happens to the small tungsten filament in your headlight?I would think too small wire would prevent the fans from drawing as much current,
I would think too small wire would prevent the fans from drawing as much current, actually making my problem better (at the expense of hot wire and slower fan speed). For preventing surge current, maybe just a big-big low ohm resistor in line with the fan would be the ticket.
I'm really confused by the fact that my system can't maintain charging level voltages with the fans and lights on. I'm around 12.5 V with both fans and the headlights going. I have a brand new 140 amp alternator installed. What kind of alternator does a Windstar van have that it can run these things and still charge? Or maybe the ECM on those vans cranks up the idle when needed.![]()
