badmix
What is the consensus on Fin/Plate versus Tube/Fin for Trans Fluid Coolers?
Any pics of trans coolers mounted?
It comes with everything needed, mounts, fittings, hose, screws, etc. I just mounted it in front of the radiator, passenger side, between the hood latch and horn. Be careful not to put it in the way of the hood latch. LOL opps I'd be curious what the consensus is about different coolers. . Be careful not to put it in the way of the hood latch. LOL opps
Your tranny cooler is almost identical to mine. I am a bit paranoid, but I doubled up on the hose clamps.
my first postWhat's involved in hooking one of these up? I'm set to swap my TH350 for a 700R4 in the next coming weeks so I'd like to hook one up.
Does anyone sell a kit to mount them to our trucks or does it involve a little creativity and fabrication?
You want the hot fluid hitting the radiator cooler first and then the aux cooler and then back to the transmission. Most kits come with 4foot section of hose and connectors etc. Use only rubber hoses made for Trans Coolers, not Fuel Line.
my first post![]()
Its pretty simple to add a cooler. The hardest part is where to mount it. but with the space we have in our K5s, space Isnt a problem.
if your radiator already has the cooler built into it, youll just have to take the return line and run that into your aux cooler and then the output of the aux cooler will tie into the return line going back to your radiator.
On a 700r , on the side of the transmission, there will be 2 lines. The UPPER line is output to the cooler and the LOWER line is the return from the cooler
What's there to argue about the radiator is the most efficient at removing heat since it contains water. Water removes more heat then air.I think this one is going to get argued over, depending on individual climate conditions..![]()
