I’m ditching my Stage 8’s and doing the 14 bolt set up next time I have mine apart.
He breaks everything though, should that be the deciding factor?I can’t ever remember how the Stage 8’s come apart, I always struggle. When we had to fix @mrk5’s in Moab somehow his got messed up and was a pain in the ass to get apart. Kevin showed us the 14 bolt trick and we were sold. Literally we bought a set from him.
How hard is it to remove the rear most crossmember with the body on?Slowly making progress. Completely stripping off the frame rails of everything. I used every loud noise making tool and I'm sure my neighbors at absolutely thrilled.
I still get a laugh out of them calling you Wreck-it-Ralph!Slowly making progress. Completely stripping off the frame rails of everything. I used every loud noise making tool and I'm sure my neighbors at absolutely thrilled.
Plasma cut out the cross member and that allowed easier access to the rivets that I knocked out with an air hammerHow hard is it to remove the rear most crossmember with the body on?
Shhhhhhh don't say that! It's been loved......gently.Why not just sleeve the frame with like some 2x4? Looks pretty beat up.
That frame and your shoes seem to be in the same shape!Slowly making progress. Completely stripping off the frame rails of everything. I used every loud noise making tool and I'm sure my neighbors at absolutely thrilled.
We got some hard miles, but still workin!That frame and your shoes seem to be in the same shape!![]()
I just thought it would be easier and give you a solid platform to build off of.Shhhhhhh don't say that! It's been loved......gently.
I'll be adding in plates to box in the frame
Once the rear is linked and the shocks tie into the roll cage the frame from where the links mount and back doesn't support anything critical anymore, boxing just helps with twisting.I just thought it would be easier and give you a solid platform to build off of.
I'd have used the plasma to knock out the rivets lol.Plasma cut out the cross member and that allowed easier access to the rivets that I knocked out with an air hammer
I also use my plasma for those.I'd have used the plasma to knock out the rivets lol.
That's the only way I take em out anymore.
Lay it sideways, shave the head off and they pop right out.
If your good with the plasma you won't even hurt the frame or cross member.
Mine easy because I just leave the ground off. Some shut off if the ground isn't on ive heard though.
I started this. I used to cut a slot in a river and air hammer them out. Then got lazy and discovered how easy it is to melt the rivet off and doneI'd have used the plasma to knock out the rivets lol.
