random items for sale in NW oregon.
colbystephens
1 ton status
Oregon
ok, so the pic's show it all. no reasonable offer refused. prefer not to ship, but i can. also, don't have pics at the moment, but i've got some decent non-stock wall panels for the rear of a blazer. they're nice - i'll snap some shots soon. also got an extra set of rear slider tinted windows from a model similar to an 83 year, minus the latches. those will go $100 OBO. buyer pays shipping.
complete 454 wiring harness from mid 80's. don't know much about it.
not perfect, but pretty nice. the back circuit is a bit messed up so that the volt meter doesn't work, and there's something screwy with the right turn signal.
i'll let this go for real cheap. circuit's not perfect, but manageable.
a/c rad - a bit bent up, but ok. i've got a couple pieces of a/c lines too which will go with it.
off a 700. one small hole in the bottom.
hey colby, Im interested in the wiring harness. I need to replace pretty much all of the engine related wiring in my crew cab with a 454. Is the fuse block still intact? How did you come to aquire it? I only ask because I wondering if its been hacked up or anything. Do you happen to know what truck it came out of? Thanks...
i'll check on the fuse box for you. i got it from another member of ck5. i'm pretty sure it comes out of a mid 80's crew cab. i know that it's not hacked up in any way - just simply pulled from the rig. :) i'll unwind it tonite and snap some detail shots if you like.
ok, it's from an 83 2wd burb. it's got the power locks and windows. complete and uncut. i'll get pics tonite, like said.
Great I would appreciate the pictures very much. I am only planning on using the engine compartment wiring, my truck had a little fire and damaged most of the wires under there. Do you know if it had a/c? I imagine it should be pretty easy to tell what part of the harness is the engine looms. Then with those pics I can compare to the mess I have under my hood.
shoot! i forgot to snap those pics last nite. when i get home this afternoon i'll be sure to do it.
Not a problem, whenever you get around to it. My crew cab had that fire way back in july and has been sitting ever since so I dont think Im in a huge rush. lol.
fuse box is complete. even has trailer wiring harness and lighting harnesses included. good stuff.
Thanks for teh pictures, Im going to do my best and try and see how those pics look compared to my current setup. Also Im going to talk to a few of my buddies and look at wiring diagrams to determine if that harness will work. Im not entirely sure as of right now but I think the 3/4 burbs had the electronic carb, which my crew cab does not have. But Ill do some research and get back to you. Thanks for the pitcures, there going to be a big help.:thumb:
Is there anything broken on it? How much shipped to Mesa, AZ 85202?
the circuit on tha back isn't in perfect shape. i've run it in my rig, and i don't think the volt meter worked, and the right blinker is funny, but worked (iirc). i would suppose this could be taken care of rather easy with some solder. i don't have the screws for it which hold al the pieces together either.
shipping to mesa is free if you can wait until mid december, as i'm driving down there. if you're real interested in it, i can just bring it so you can give it a good look, but i'll be bringing a ton of stuff, so please don't waste my cargo space if you're not super intersted.
