Really kinda hate my Fitech
There is a group on facebook you can get help from. they are real good with the system. they are a bit touchy though
FiTech owners group
Hah yeah bunch of cocksuckers on there. Yeah I got kicked out. For reporting a shit post. It was a group moderator shitposting and he got all hurt about it.
If you have to pull the pedal back up with your toe, I'm wondering what is up with the throttle return springs.
Are you running g a return spring?
And yes they got pissy the last year or so
here is a test for you have someone you trust sit in cab while you watch throttle with it off and with it running hit the throttle under the hood and the pedal try and eliminate where your hanging up and what 1-ton said
Are you running a return spring?
I am using the factory FiTech setup for the return spring pressure. I have a Fast EFI throttle cable bracket that holds the th350 detent cable. I actually moved my throttle cable connection up on the lever to increases leverage and reduce the pedal pressure needed to move the throttle. I don't get 100% full throttle, but the intake doesn't take any more than about 75-80% anyways. If I had a hungrier motor I'd go with the full spring setup from Fast for this bracket and use their return springs. I have it hooked up with some spacer and washers to make it fit on the end of the lever.
and i went to lokar throttle cable, the stock one would cut into itself leaving me stranded
I have a lokar cable but untill I figure out how to get this first Gen bell crank throttle assembly off the firewall from behind the head I can't do anything with it. Anyways even with the throttle bar disconnected it still hangs up so I'll have to get out there and find out if it's hitting the dual plane intake throat
No point messing with tuning while the physical problem exists. Once that's solved you can see what the other settings actually do.
I remember chatting about your issues in your build thread and I still come to same conclusion that mechanically you have an issue with your linkage that's snowballing. First and foremost your pedal must be stiff as shit with this setup, you need to move your linkage higher so it has more leverage/softer pedal. See below....
and if you throttle blades are sticking that should be easily diagnosed with a visual inspection of the throttle body.
Not very helpful I know, but I had the same problem for like four or five months. Mine would never idle down and everyone was saying adjust your IAC non stop (The same Facebook group you guys are talking about). Then they were saying i have to have a vacuum leak there’s no other thing it could be and were telling me to pull off my intake and change the gasket, but I knew I didn’t have a leak. one day I got so pissed off I went and bought a holley, when I put it on there and it ran and idled perfectly and I’ve been running it ever since.
I hope you have better luck than me but it seems like sometimes these things just don’t want to work .
If you’re having to adjust your IAC over and over you have other problems. Carbs can run fine on an engine with ignition, vacuum and exhaust leaks however EFI will not.
My stock TBI in my 87 did the exact same thing with a shitted up stock cable and my street truck did it too with a carb. A lokar universal cable was one of the best investments Ive ever made. I know you said the issue is persisting with with linkage unhooked but as others have said you need to find your mechanical issue, because you simply cant tune that out.
Other than the butterflys hitting the intake is there any chance that your poor linkage angle has bent the throttle shaft? FiTech is budget stuff, it may be well made but that doesnt mean its beefy. Take the unit off and see if its hanging up on a bench.
Also setting the idle stop way too low can cause this to happen too by the butterflys returning past their neutral closed point and this will also cause the RPM to pick up. If you're trying to set the idle stop screw too low to bandaid the IAC not being properly set up then you are severely chasing your tail.
OK so I'm tuning the governor in my th350 so just out on my normal pavement only duty bc the passenger door keeps flying open when the body flexes and the ol lady almost falls out.
Anyways, if you fallow my build you'll know already that I can't get this fckn throttle body to idle correctly or return all the way. It's really pissing me off. To the point that this stroker is plowing through the brakes unless I pull the pedal lever back up with my toe. (can't leave the pedal on for that reason)
Now I know I'm a novice when it comes to this new fangled electronic fuel bs but I'm pretty sure I've fallowed the iac steps that only got me down to 800rpm I'm shooting for 700. I also can't turn the idle screw in for that reason so the butterflies stick in the throat after I pull it back up! Also causing drivability issues.
It is not the throttle linkage! It does this when it's not connected as well..
Im seriously annoyed.
Fitech only responds with how to fallow the iac steps. This does not work.
I'm seriously considering taking all this bullshit back off and putting a carb back in that I know I can tune and make idle.
Where is the benefit to this system?
I have a FITech on a Roush 427 stroker motor, I didn’t do the install myself, and I love it. Starts easier, doesn’t flood the bowl, has better throttle response and best of all, about 26 more HP! I would never go back to a carburetor again. I wish I had some trouble shooting ideas for you but it looks like you’ve had some good feedback. Best of luck
I'm at the point I think I have a defect but I need to call them when I get free. It starts and runs fine the throttle sticks
