rear 52'' or 56" leaf springs?
The K5 came with the optional heavy duty front springs rpo f60. would this still be 52in?
Mine is an '89, i had a friend that had an '87 that had 52's,, i dunno though, just stating what i saw :D
I'm thinking about putting 1 ton running gear in the K5. This would be the 14 bolt FF rear and Dana 60 front. Would I still need 52in springs or would I need 56in?
Still need 52s.
Or do a shacke flip and run some stock 56s from a 1ton.
Still need 52s.
and if shackle flip bolt the brackets on backwards of directions to get the spring eye bolt hole in the correct place for 56" . basicly swap left to right and right to left.
speaking of 52" rear springs....where is the cheapest place to get them? I decided to go that route and am shopping.
I don't know about going with the cheapest. Unless you don't mind the buck board ride:doah:. ORD sells tuff country. They ride and flex decent and in my opinion they are priced well.
I'm running 6", 52" Rough Country springs in the rear...
I need a neck brace, helmet, and a chiropractor on call when I'm offroading...
BUT you said cheap and that they were (BTW, I would never buy them again!)
I have tuff country fronts, so i was expecting to do the same for the rear. best place/price to order them?
