That sounds like a bench job. Some shops do not like doing a bench job because when the install goes wrong they blame the shop that put the transmission together. The price I was quoting was taking the vehicle in to do the whole job. I want to do my own transmission because there are known problems that the early model 4L80E transmissions had. I have done a lot of research on this, and intend to fix them. I would not trust any transmission shop to know or care what these known problems where, or to bother wanting to fix them.My local trusted trans shop, that does everyone's race transmissions and such, quoted me $2800 to rebuild my 4l80e and make it reliably handle 800hp.
Last summer anyway.
I am following along because I need to rebuild a 1991 version as well...I want to do my own transmission because there are known problems that the early model 4L80E transmissions had. I have done a lot of research on this, and intend to fix them.
That's me taking the vehicle to him and he does it all. I trust him fully. He's done 4 in the past for me and a few more for friends and family. If there's a problem or trick to know about em, he knows it.That sounds like a bench job. Some shops do not like doing a bench job because when the install goes wrong they blame the shop that put the transmission together. The price I was quoting was taking the vehicle in to do the whole job. I want to do my own transmission because there are known problems that the early model 4L80E transmissions had. I have done a lot of research on this, and intend to fix them. I would not trust any transmission shop to know or care what these known problems where, or to bother wanting to fix them.
When your transmission builder says increasing "800 HP" they actually mean 800 -foot pound torque. They are doing that by installing a billit forward clutch hub. That only applies to the early model 4L80E transmission, which came with a cast iron forward clutch hub. The later models in 2001 changed to a billit one from the factory. $3000 is cheap when labor is factored in. I do not trust anyone to work on my rare 1991 V3500 Crew Cab. If I handed over the keys to any shop to a truck like mine they would steal it because there is way more money in stealing a truck like mine than there is in fixing it.That's me taking the vehicle to him and he does it all. I trust him fully. He's done 4 in the past for me and a few more for friends and family. If there's a problem or trick to know about em, he knows it.![]()
My transmission is actually a 1993 version 4L80E that was installed under warranty by the original owner many years back, but is still an early model version of the 4L80E. The odd problem with the first year 1991 version of the 4L80E was the "temp switch" they came with in the valve body. When you buy a internal wiring harness they are an updated version only, which does not come with a temp switch terminal end. When you buy an updated wiring harness you have to update the female end of the wiring harness. Most new internal wiring harness will come with all the female end kit to update it.I am following along because I need to rebuild a 1991 version as well...
If you buy one of those transmission bench stands you have to buy an adapter for about $20 for it to work on a 4L80E case. Another tool is a drum clutch spring compressor tool. I do not have one because I am going to use my 20-Ton press to lightly compress the drum clutch springs, in order to remove the snap rings. I just have to take a flat piece of steel, and bend it into a U shape that is the correct width.Any special tools needed for a project like that? Besides the stand/mount to hold it vertical.
Other than some big snap ring pliers I have basically no transmission tools, yet I've done a number of them. I usually fabricate my way through, but what's a few more hours in a 1-off job compared to web searching, ordering and waiting for tools compared to getting it done today?Any special tools needed for a project like that? Besides the stand/mount to hold it vertical.
10-4 on that one. The one thing I bought for this job was a steel work bench to lay out all the parts, and mount my transmission bench stand to.Best advise is to have shelves or tables to lay all the parts out on
It whined all the time after the transmission warmed up. Think I found the problem though.Did it whine at idle in park?
Or just as it went up thru the gears ?
