I would try to throw that drum on a lathe and polish it first. If you can get it smooth again without turning, it will have a better outcome.
That is probably what I am going to do. From the research I have done a new front planetary hubs are not available, but remanufactured ones are, and it looks like all they do is take a few thousands off on a lath then put new roller pins in the planetary if needed. There is a guy here in town that rebuilt my torque converter, and he also rebuilds transmission pumps by taking a few thousands of with a lath. I will take my front planetary to him to see if he can machine back to smooth for me.I would try to throw that drum on a lathe and polish it first. If you can get it smooth again without turning, it will have a better outcome.
That is true. The transmission whined all the time whether idling or in gear. I inspected the pump gears and vein ports, and it is in perfect condition. I have not pulled out any pump pressure valves yet. The torque converter is at a guys shop that is going to open it up to clean and inspect it. I also inspected the flex plate and rear crankshaft area, and it looks perfect as well.But those parts aren't moving unless the vehicle is moving. While stationary, only the torque converter and pump are spinning.
Since my transmission whined all the time after it warmed up, I need to concentrate on the flex plate, torque converter, and pump area to find the problem.Input shaft would still be turning some internals, just not hydraulically coupled... not until clutch pack pistons and bands apply...would everything stop.
I took the pump halves apart and they look perfect. I even had the guy who built my torque converter and rebuilds pumps look at my pump, and he said the thing looks perfect. The only thing I have not taken apart on the pump to inspect (yet) is the pressure control valves. I have Sonnax pressure control bleed off pressure valves in it, but I still need to inspect them.Well you're already having the converter done. Have you taken the pump apart? Some shops sell rebuilt ones ready to drop in, if it will be stock. Although your super early model could have some difference.
I believe it's possible to get some whine from a good pump that's working at high pressure. It's possible a valve is stuck or bore worn. This may be more of an @Greg Ducato level question.
I used a stethoscope to locate the whining sound. It sounded like it was coming from the torque converter/pump/or just behind the pump. Fluid was in good condition. I did find a small amount of steel stuck to the rear speed sensor magnet where the rear output planateries and reverse band are located. Nothing was stuck to the front speed sensor magnet. A small amount of steel was stuck to the pan magnet, but it was a very small amount.Looks like good work there. Long live us DIYers.
Back to the beginning...you pulled the accessory belt(s) and/or unbolted the torque converter to verify noise source? Or was it stethoscope or similar?
I thought you said fluid looked good. Where is the wear material from band/drum?
No, I never did do that. I do not have the tool for that, but I will probably get one to check pressures when the transmission is back together. The whining noise coming from the transmission could be heard even without my stethoscope. Once the whining would start after the fluid got hot I could hear it just standing next to my truck coming from the transmission torque converter area. If the torque converter is not the problem then there is a possibility that a pump pressure valve got stuck. A pressure reading would have been good for diagnosing that. I will get to pulling the pump pressure valves soon.Do you have line pressure measurements?
Did you replace the bushing in that center support? If not you should consider it, it more or less supports the direct drum via the sun gear shaft.
My center support bushing looks almost new even though I do have a complete new bushing kit with my rebuild kit. All of the bushings look new, which surprised me. I think someone may have had this transmission rebuilt just before I bought this truck. The transmission has a sticker on it saying it is a GM Service Replacement Transmission from 1993 that was probably replaced under warranty, but all the seals and bushings look so new I think it was rebuilt again sometime before I bought the truck.Did you replace the bushing in that center support? If not you should consider it, it more or less supports the direct drum via the sun gear shaft. Also, if you plan to machine the reverse band apply area use the correct style band for the finish you obtain and lengthen the band apply pin as needed for correct clearance.
I would rather have a high quality OE flexplate than an SFI all things considered, especially with 6 bolts on the converter.
