I've searched and can't find a thread that shows step by step on removing a th350 and NP203.
If there is one could somebody show the link and also what's the best manual on these transfer cases and transmissions?
Honestly it's probably just too straightforward to bother with. I think my Haynes and Chiltons both have a step-by-step thing on it, but I've only ever referenced them for torque specs and the 203 shifter adjustment.
I find with the COG of the 203, it's usually easier to just remove the tranny and tcase together with the crossmember if you have a jack. If you don't have a jack, I have been able to unbolt the chaincase from the gear reduction box on the 203 in the truck (this is really dependent on the floorboards, I don't see how you could do it on a Sub but it's easy in a K5).
If you just want to remove the whole 203, the tranny adapter has like 8 bolts or something roughly in a bean shape. They're all relatively easy to get to, but if you have a removable tranny tunnel, it will make your life a whole bunch easier. There are two of the mounting bolts holding on the shifter BTW.
The bellhousing on the tranny is a whole lot easier if you have that removable floor panel too. For the top two bolts on the bellhousing, you pretty much have to lower the back of the tranny down a few inches due to firewall clearance. Be careful though, it tips the motor backward too and you can damage your distributor. Also note that with the tranny mount gone, the motor will probably need to be supported to prevent it from tipping backward in to the firewall. You can just put a jackstand with a board under the back of the oil pan, but then it's in your way. I prefer to tie a rope or something to the lifting plate or a bracket on the front/top of the engine and strap it to the core support, front bumper, wall, etc.
A set of long extensions are pretty much awesome for doing bellhousing bolts. You don't need them, but they're totally worth it and come in pretty handy.
http://www.summitracing.com/parts/TTN-12079/
If you're asking for a manual for the th350, this book is worth it's weight in gold. I'm pretty sure everyone that works on them owns a copy.
http://www.summitracing.com/parts/HPB-HP511/ Honestly I would pay $50 for it if that's what it cost, it's totally worth it.
I don't know of any manuals for the 203, but there's plenty of exploded diagrams on the web. The thing is incredibly simple and all you really need is some Assemblee Goo and a 9/16" wrench to rebuild it. Oh, and sockets for the yokes. th350 thrust washers and shims seem to work well enough for adjusting endplay on the output shaft if you want to get that involved with it. I think spec is like .008"-.012", but if you just get it snug but still smooth and rotating freely it will be just fine.
