replacing body mount bushings
there is enough play, they are coiled. if you are worried unbolt the master from the booster. No need to open the hydraulic system
I have two jacks I can use to lift with. I'm going to spread the weight using a 2x4. I'll start with the passenger side and try to lift it equally front to back. I have the gas tank removed and only the drivers seat is installed in the interior.
I did a 3" body lift on my jeep wagoneer, and I loosened both sides then took one side off and lifted in the middle and the whole side went up evenly.
I just did my bushings I had to jack each side of the cab up, separately, about 8.5 inches to get the original bushings out and install the new bushings.
I used my farm jack to provide the lift. The bolts all came right out. I cleaned and painted all the surfaces that the bushings came off in contact with.
I used a my half inch impact tightening the bolts until they squashed the new bushings by 1/2 inches. With a dab of red axle grease on each bolt to cut down on the whole corrosion thing.
I did not loosen or move any brake lines. No problems.
Was this on a K5?
I'm using new rubber mounts from LMC made in Taiwan. The metal on the new rubber mounts is not painted. I'm wondering if I should spray some paint on the new mounts.
I also drilled a drain hole in the cup washers and cut small grooves to allow anything that gets in them to drain out. The old ones I pulled out had a lot of rust inside, I figured it was from lack of ventilation/drainage. Seems to have worked the last 20 years.
