Nope. He never sent me an email after 3 phone calls saying he would.
I was always wonder, maybe life is easier if you just don't care about it.I have been ghosted by the ECU and harness guy. Was supposed to be 2 weeks. Monday was 4 weeks from when he emailed that he got it. Said it was shipping Tuesday. Not returning emails or calls now. How do people stay in business this way?
Yeah, I have the hypertherm and tips definitely go faster piercing vs starting from an edge.My memory is so bad I don't know. It's green. Piercing the materials is what seems to kill tips.
I had that problem until I started pointing at 45 degrees until the groove is through the other side then I go vertical.My memory is so bad I don't know. It's green. Piercing the materials is what seems to kill tips.
It's the splatter and the trapped heat that kills the tip
Both are not conducive to doing on a CNC table.Drill a 3/16" hole where you want to pierce...save your consumables.
You get a tax write for consumables so there is that ................ Pierce away BatmanBoth are not conducive to doing on a CNC table.
Thanks for the info on that kit.It’s good to do the trans cooler the way you are. The cheap/easy way guys just throw a -6an billet block on there and plumb to the cooler. But the way you’re doing it with the correct bypass setup can save your transmission if the cooler gets plugged or you pinch a line.
You bet.Thanks for the info on that kit.
