roll cage to body or frame?
BadDog said:
But I would again urge everyone to reconsider using the common dog-leg "easy way" to tie to the frame. The down sides from that FAR outweigh any benefit IMO.
could you expand on this a bit BD? I plan on having my cage attach to my body in atleast 10 points... but was going to use the "common dog leg" on atleast 6 of them to firm things up a bit. I want the cage to be resistant to both high and low speed crashes/rolls as I still drive on the interstates from time to time. I really value your opinion on this.. just wondering what you would suggest for those that want to tie their 'pod' into the frame. :grin:
Stephen basically says 'weld it up solid' if you're going to attach it to the frame... does that mean pull the body bushings too? Seems like they'd be pointless if you welded the cage to the frame.
j
Another thing that nobody has mentioned is,
the best cage is no good if you dont secure all your crap in your truck.
Things that could really help out on the trail when your brokeI.E.; stub shafts, axles, hi-lift, u-joints and so on. These items could seriously hurt or kill you and your passengers if not secured properly in your rig.
I have thought about this for a bit. what do you think about tubing, say 3' welded or welded and bolted at the rear of the frame that extends out to the sides to just inside the body in key points on the frame so you could tie cage into the frame farther out board the just the width of the frame itself. you could tie your tube bumpers into them aswell. thats kind of the way rock sliders work if you tie the frame to them. just a thought.
To me, the answer to this question is very simple. You can do it the way ALL the serious professionals do it, or you can do it like Backyard Bob would do it.
I’ll put it another way. I’ll pay for Walker Evans Racing to build you a full cage tied to the frame and body or a cage tied to the body only, your choice. I’m guessing you would all pick the first option. So what it really comes down to is money, like in almost everything.
Regarding frame flex: I like to try to eliminate all frame flex and let the suspension do the work. A rigid chassis is the goal of any competitive builder.
TrcksR4ME said:
Did I miss something here? I keep seeing stuff like "racecars" do it this way, etc. However race cars are not articulating over boulders and probably aren't built on frames that are designed to flex. My biggest peeve in this thread is all the racecar comparisions, because these trucks are not going 200 mph or whatever. They also are not going down flat paved road. It's an apples to oranges comparison and should not be used.
That's true, but it doesn't really matter what the speed is. A roll is still a roll. Obviously the loads change with speed, but if you do your best to design for a 100 mph roll then the cage (& you) will better survive a .5 mph roll.
One thing most people overlook when building a roll cage is the bottom of all of the hoops. It's rare to see them tied together in a 'Sport Cage'. Usually they are simply bolted to the body, which may or may not have the strength needed to keep the bottom of the hoop from closing up. You can NOT count on the body to be structural.
The reason GM designed the frame to flex is not b/c that is a desireable trait. They did it b/c they knew that with a ladder type design that they couldn't stop it from flexing, so better to allow it to flex a little and not have the flex kill it than to try to make it rigid enough to resist the flex (ain't going to happen). If they had the option of building a space frame (cage tied to frame) then they would've built it so that it would not flex.
If you're going to build a so-called "pod" cage (i.e. not tied to the frame) then the seats and seat belts should also bolt to it. If it separates from the body when the seats and belts are bolted to the body, the cage will do you no good and may actually hurt you. This is a good idea even if it's not a "pod" cage.
BAJA_BLAZER said:
snip.....
Second that! Works for play/sport vehicles too.
Second that TOO!!!
So the cage thing always goes in the extreme direction of beefing up sections of the frame and not others. This creates a localized flex area that fatigues quicker than the rest of the frame and ends in failure in one way or another.
So lets say that we build a good cage that only ties to the body. The seats, harnesses and all spare parts etc. are mounted to this "pod" within the body. Lets say that you flop over a few times and stress the body a little bit in places but the pod is holding strong. Next take a multiple roll situation.
1. Does this pod try to seperate from the body?
2. Does the body want to seperate from the frame?
These are questions that are so highly variable in the answer that I don't even want to go there.
The second part of my thoughts are that if you beef up the body to the point that it will not flex with the frame you begin to fatigue body mounts. Much in the same way that that beefing up one section of the frame is going to cause cracking problems down the road.
So here is my .02 Build a cage tie it in to the frame where ever and however you want. Tie the cage to the body as well.
It is MY OPINION that we are over anal about the cracking of a frame in a vehicle that is already near twenty years old and on it's way out the door. This does not mean that cracking is okay but it raises the question what is the remaining life span of the vehicle in the use that you are giving it. I think that the life span is short enough that the localized flex here and there are not that big of a deal.
There is my .02.
All:
On the "pod" theory, I have always reinforced the floors going over the frame. Do not trust the floor alone if you have any real expectation of seeing a roll. In my truggy I have 2x3x0.188 square from one side to the other in back from the bottom of one main hoop to the bottom of the other. On the "a-hoop" I have 2x2x0.188 mounted in a sort of cantilever for similar effect but without having to go across the trans (which at the time would have been too much trouble).
And to all those "do it right" folks coming from desert racing and hard core rock crawling, remember the majority focus of this site. Most of these guys are still worried about body panels and are not going to go where they are likely to roll, but wisely want a roll cage "just in case". These trucks do 99% of their time on the street and need to remain relatively comfortable in the winter, rain, hauling the family, etc. They also don't want to "get out their purse" (Brandon and co. ;) ) to go "all the way". So for 99%+ (and I feel VERY safe in that number) of the people on this site who are interested in cages, the frame tie-in story is completely over the top and around the corner. They also have put a lot of money into their trucks and fully expect to use them for "mulit-use vehicles" for years and many thousands of miles to come (whether this is realistic is another debate). The drawbacks and costs of "to the frame" DRAMATICALLY overshadow any benefit they are realistically likely to get from it. So the "pod" style supplies the "just in case" safety as well as the comfort and long term viability requirements. Why are so many people so utterly contemptuous of this? Frankly, I think some of you would insist we all drive a Lamborghini Diablo to and from work in rush hour traffic for 5 miles through downtown Manhattan just because "it's the best" for some imagined reality. Frankly, I would rather drive something more comfortable and suitable to the real needs at hand.
In fact, this strikes me as very similar to the "can't wheel without a Dana 60 front" tendency that runs so rampant on the web. A small subset of us who long-ago (or not so long ago) gave up body and looks as well as realistically "streetable" probably shouldn't even consider "pod" style. In fact, the "pod" is probably MORE work for "us" than "doing it right" to the frame. I did my "pod" long ago before I got nearly where I wound up, and while that cage holds up, I lack the energy, time, money, or inclination to change it now. But I would never rebuild it using the body mounts if I did it now. My son's K5 (which is still not done, he lost interest) is a perfect example of the other side. His truck was to be 99% road truck with "fun days" running the fire roads and moderate rock crawling. It needed to be VERY streetable and he wanted to keep the body mostly stock in over-all appearance. The answer for us was obvious to me. We reinforced his floor (as part of the boat side) much like mine was done and prepared to build a "pod" with seats and belts mounted into the cage.
Bottom line, neither approach is "the right approach" across the board. Each person needs to evaluate their needs and with the pros/cons for *their* usage. I'm very vocal on the side of the "pod" or body mounted cages ONLY because everyone else seems to jump so energetically onto the "TIE IT TO THE FRAME" band wagon. I'm really completely indifferent to either approach and choose based on the intended use and needs for each application.
Jason:
The problem I have with the dog legs is that most form what amounts to a lever that is working one way or the other. I've seen the welded/mounted completely solid with no bushing. This works against the down tube "in bending" and against the frame just like the "bad design" steering box that so many people get up in arms about. If you put a bushing in there, depending on how the bushing is mounted, you still get these forces to varying degrees. And imagine exactly what is going to happen to that "mount" with a very hard roll. Depending on exactly what/where/how it's likely to fold, rip bend anyway, especially if it has become brittle over time from fatigue.
And yes, I believe what Stephen is advocating *for hard core use* is to eliminate all the isolators and mount things solid. So you have a cage welded/mounted to the frame in order to form that rigid "space frame" I mentioned. This cage design is intended to provide protection and rigidity without much concern for the body, so major body mods are generally required. Then the "body" is remounted somehow (depends) to the cage/frame and no longer needs isolators because the flex is mostly gone. In fact, isolators just complicate things at that point.
rdn2blazer:
That's not ideal because you've got the bar fully "in bending". It would work, but I would suggest something like I used in a similar case, 2x3x0.188 square. You know which direction most all the force is coming from, so square is far stronger pound for pound, inch for inch.
Baja Blazer:
Again, "all the serious professionals" don't have to drive their vehicles every day on the street, or too and from the trails in another state, or in the rain and snow… All the "serious professionals" also use 5 point harnesses, wrap around seats, expensive coil overs and high-zoot hand fabricated works of art for tuned suspensions, and so on. Does that make all that the "right choice" for everyone here?
ntsqd:
Agreed 100%. Only thing to add is that when you build the bars that mount the seats to the cage, it almost becomes a "pod" at that point since it will/should keep from punching through the floor (assuming the seat supports are strong enough to distribute the load).
Brandon:
For folks with trail focused trucks, I agree 100%. Trucks where we've already pretty much given up on "body" and "stock looks". What I'm trying to offer here is a voice of reason for the 99% or so of this site who are not in that category where we find ourselves. These guys ARE expecting their "investments" to last for years and thousands of miles, and those concerns (cracked frames, leaks, squeaks, expense, fatigue life, etc.) are valid for them. Your also right about the body mount fatigue, that type of stress always does move to the next weakest point, but between the bushing flex and the mount design, those can handle the stresses a LOT better and longer than the body or frame can in the typical cage/frame tie-in.
All:
My opinion is this, don't do it half way. Either build a "pod" or something similar and call it "good for my needs". Or if, for whatever reason, you feel a frame mounted cage is the "right way for you", then go the full distance and live with the consequences. Most of what *I* consider problems with the "frame mounted" approach come in ONLY because it didn't go all the way to building a rigid chassis. And that requires a (almost) fully rigid triangulated structure in 3 dimensions so that most all forces are transferred into tension/compression. If you decide to go somewhere in between, that's fine too, but you really need to understand the consequences and have judged them acceptable. If so, then good luck and have fun.
bad dog, my bad, I ment to say square tube, I just for got to, and can I say I'm glad I started this thread, it makes my feel kinda special cause so many of you have replied :D I'm gona copy every page and keep it in my blazer file. thanks again!
LOL, it's always been a contentious topic, especially since I (and a few others) started to be more active in supporting the "not to the frame" side of the argument. It just seemed there were too many hard core guys getting tunnel vision, and then AT LEAST 10 times as many wanna-bees with no knowledge, experience, or skill parroting the knowledgeable hard core guys without even understanding the implications. Partially boxing the frame (generally a lost cause attempt at "fighting the evil flex" with very little to offer other than cons), cage to the frame, "scab" plating pieced frames, and so on are all things that draw passionate responses (including fact, informed opinion, AND mindless parroting) from the woodwork. I keep telling myself I'm not going to participate in yet another thread on the topic, but I can't seem to help myself. :crazy:
At least now you have many different facts, views, and opinions to consider and hopefully find the right solution for you. Good luck.
Baddog- Great points like usual. I think that cage building has gone the way of the Dana 60 discussions. Everyone has decided the only way to do it is the theoretical (sp?) "best" way. Its almost like people are saying they don't even feel safe driving on the freeway unless they have a cage tied into the frame. The main thing here is to survive a crash or rollover, and people have been doing that without cages for a long time. A cage is an extra margin of safety for most, unless you are a true hardcore wheeler who is in the position of a potential rollovers on a regular basis. I myself in the few years of wheeling cannot remember even coming close to a rollover, the only reason i want any cage at all is piece of mind. My belief is anything is better than nothing, even if your roll bar collapses in a roll, thats is energy that is being absorbed. Better a piece of metal than your head :grin:
But you are right, everyone has to decide for themselves what is right for them. That is the problem with the web IMO, while it is a great resource, many people see so and so doing it this way, and decide "thats how I NEED to do it." I want to wheel now, I do not want to wait 5 years until my truck is built to the standards according to CK5. That doesn't mean my truck is dangerous or incapable of decent wheeling, matter of fact my truck has been very reliable overall. Everyone just has to decide what is right for them when it comes down to it, maybe even make a few decisions without a poll on CK5 ;)
__________________
'77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
http://www.krazyk5.com
http://community.webshots.com/user/trcksr4me
http://community.webshots.com/user/trcksr4me2
I will say this about a pod type cage I plan on doing for my truck.
It only needs to survive one roll over. This is because if I roll my K5 it will probably be really trashed. At that point I will probably start looking at building a trail only truggy where I can make a cage welded to the frame the correct way. Because if I'm pushing my truck that hard on the trail, then the truggy will be more pratical since I'll have probably reached that next level of wheeling where I'm running trails rated 10 (or the equivalent).
Or the rollover will scare me sh!tless and I'll be done with any serious wheeling (not likely, but possible).
Baddog as always great comments.
I laughed for the first time today at the purse comment. Just to let you know I have permanently removed the purse from the buggy. Thats why it looks like hammered crap right now.
I think the defining point here may just be TOPLESS.
I am a firm beliver in occupant safety first and foremost. I wonder if those planning for an interior cage with a factory hard top would benefit more from the "pod" style and those that want to go topless should think about a full cage to the frame.
If you roll your truck with a factory hard top over on its' lid the hard top is going to do its' job and keep the occupants safe. Roll that truck multiple times and you are asking for trouble without a cage of any nature.
Roll a topless vehicle and you are in for a world of hurt without a good cage that is tied into the frame. IMO
I am a big fan of tieing into the frame but do understand the reality of not going far enough with the cage.
And for those with body preservation in their head.
Take your Purse out from under the gas peddle :rotfl: :whistle:
This will always be a tough subject because it's safety related and the cost of doing it "wrong" (dying) are so high that a lot of sacrifices will be made to prevent that from happening.
I have seen several half cab K5's in rolled over condition and one thing that is universal is that the half cabs stand up pretty well. The windshield frame crushes in but the stuff over the heads of the front seats holds up OK. And the bodies have not been separated from the frames and drivetrains are never broken out to the point of separating from the vehicle. This leads me to agree with Russ that for most people, tying to the body will be just fine. You will need to protect the back seats, the 'glass top doesn't do as much back there. As long as you have some decent sheet metal to tie to and do it as some relatively stong points, this will help survivability quite a bit. The point above about a significant crash totalling the truck anyway is a good one. Do you care if the cage is bent up after a crash in a full body truck? You shouldn't as long as you're alive, the truck is totalled anyway.
A bar connecting the legs of the "B" pillars is a good idea, as is a bar connecting the bottom of the A and B pillars across the doorsill. These can be very unobtrusive.
This always comes down to how you want to use your truck and how well you know it's limitations and behave in a way that stays within those limitations.
I just finished reading this thread and have a question...
I saw someone on here do it, but was wondering, if you could tie your cage to the body, but right underneath the cagemounts, there would be another mount that connects to the body mount and the frame. So basically, for a DD/trail rig type truck, would you get the extra space from not tieing directly to the frame, but still have somewhat of a "tied to the frame" strength?
Hope that makes sense...
i agree completely. if you mount a cage to the body and roll whats to stop the cage from poking right through the sheet metal (and probably rusty) floor?
Great info as usual. I have been pondering several designs for my cage. I have decided I will do the sandwich method to the floor and then to the frame. I like the plates that DIY4X4 has.
I was planning on connecting the hoops together near the floor both front and back and the seats and harnesses cage mounted. I was just thinking if I do the same under the rig near the floor board would that also make it more rigid and maybe lessen the chance of the frame cracking????
Just in case there's any confusion, I''m with BadDog and I don't buy into the "Need a blank to go wheeling" deal either. Just remember that you don't have a cage while driving off road.
If one were looking for a "roadmap" for the progression of a cage I will offer this:
1) Build a roll bar with the idea that you may be building a cage later. Partly or fully design that cage even if you don't build it right away. That way the roll bar will fit into future plans. Try to pick mounting points where GM made the body to handle loads (like on/near a body mount).
2) Build this "pod" concept and tie it to the body Make it such that you can mount the seats and the belts to it. Build it such that the body is not needed for anything other than a place to bolt to. During a roll you don't care what the body does, but you do want the cage to stay intact.
3) As your skills/needs/worries ramp up, tie the bottom of those body mounting points to the frame via some sort of bushing.
4) Next step, make the rock skis load bearing and rigidly attached to the frame. Move the cage mounting to the skis, again via bushings. Delete the stock body mounts.
5) After you've caved in the sheetmetal far enough that it's not easily recognizable, cut the bushings loose and take the cage straight to the frame. Do what you want with the sheetmetal that is miraculously still flying in formation with the rest of the vehicle.
If you're thinking to head straight for No. 5 then do yourself a favor and start with first removing all of the sheetmetal. Can always hang it on later. The sorts of compromises you make with the sheetmetal still in place will cause you lots of unnecessary work and leave you with an inferior vehicle.
1. You put plates on the bottom of the tubes above the body mounts. the strongest points of the body.
2. Run tubes along the floor from the A pillar to the B pillar. Then run tubes across the floor between these tubes and mount your front seats to those.
If you hit hard enough to punch all of that thru the body. Then you're in more trouble than a few more pieces of tube will help.
So Bad Dog, Miniwally, and Stephen sence you guy's are more to the "hardcore" side, how do you feel about a exo cage? Can this been done right? can it be strong enough to protect the people in the truck? The main reason i want to do this is so when/if i do flop my truck i dont have to rebuild the whole thing, but of course if it affects the saftey of my passengers/family, i wont do it. Thoughts? Ideas? Opions?
My opinion on exo cages is that they are ugly things that have no function on a vehicle.
The problem with an exo on a vehicle is that they really provide very minimal protection to anything because they are so hard to build support into. Tubes tend to bow and dent the sheetmetal anyway.
Since there really is very little structure of any strength to tie into on the outside of the vehicle they tend to be weak in a roll over situation.
That is my very limited knowledge and opinion on exo cages.
