hey guys just did a head gasket so had everything apart dun dun dun lol anyways I'm very sure I got all the grounds on everything is connected properly when I first start the truck everything runs fine for about 5mins then all of a sudden it sounds like it's missing or timing is off ! I replaced the ignition modual the other night be cause it would run the cut off and not start then is key off crank again and it would fire up then die again just curious if anyone has had a problem like this or can point me in a direction thanks 87 blazer tbi 5.7
