Hossbaby50 said:
. If you have a pickup a shackle flip might not be for you. They are not recommend it you tow anything of decent weight.
Harley
This makes sense to me because of the added stress of the leverage.. But on the other hand I see people saying that a shackle flip is fine for towing It seems like every post I read where somebody ask if they can tow with a shackle flip you hear every other person say something different
I would like to go with a flip but I don't want to sacrifice towing to do it because my truck will be used for multipurpose..
Now as far as what lift to run most of that has been covered but I will add to it just a little.. I just bought a truck like the white one in the picture except mine is a K20 and has a 14 bolt ff and a Dana 44.. It has 2 inches of lift and 33 12.50"s but it had 35"s and it cleared fine..Now I guess you could get the 35"s to rub with full flex but I didn't try.. I took the 35's off because they had some leaks and were getting bald.. The only reason that I got the 33"s on there now is because the fellow I got the truck from just had bought them brand new and didn't have them mounted when I got it so I used what I had..
I think a few things to consider when your looking at what lift clears what tire is, If your going to go where some of these fellows go { rocks,hills and a lot of off camber stuff} then you might want to run low lift, big tires and fender trimming.. A example would be 4inch lift, 38.5 tire and fender trimming.. You said this was just going to be a daily driver so you could go with a a diiferent set up.. A example would be 4inch lift 35 or maybe a 36 inch tire and no fender trimming if you are just going to stay on the highway.. But what fun is that
In my area the only thing we have is mud so my truck won't see much articulation and flex.. I think the closest trails for me is about 6 hours away
. Some of these guys are very lucky because they have all kinds of trails and hills and such to ride around on... So they set their trucks up to handle that type of terrain.. So keep that in mind when making your decision
For what it is worth the lift laws around here suck so I'm going with a 6inch lift and 36 inch tires.. The 36"s and a 6inch lift would put me just a hair over maximum legal height
