Rubicon Trail 2013 (Post 7: Trail report + Pics!)
colbystephens
1 ton status
Oregon
I just got home from this year's Rubicon trip. :woot: It was rockin! We took three days to do it: one day to do the first half, a second day to swim/hike/explore, and a third day to drive out. I'll post a full trip report tomorrow, but for now I have three teaser photos for you.
From Overlook Point at the top of Cadillac Hill:
Rubicon by colbyjstephens, on Flickr
From the big long hill climb out of Buck Island Lake on the way towards Loon Lake:
Rubicon-2 by colbyjstephens, on Flickr
Rubicon-3 by colbyjstephens, on Flickr
It was a killer trip with very minor issues on the trail. I ended up with a broken transmission mount on the beginning of day one... :doah: So I had to use ratchet straps to hold the transmission in place, and that worked well enough to get me off the trail in one piece. I also had a tear (and thus a major leak) in the rubber adapter between my power steering pump and my secondary reservoir, but with enough thinking and duct tape, I got it all sealed up and working fine. Otherwise I got through the trail unscathed. :D
Like I said, a complete write up to follow. ;)
I forgot how incredibly beautiful the Sierra Nevadas are! The Rubicon by far is my most favourite wheeling location so far... I can't wait to go back next year!
Rubicon Trail Report, 2013.
If you're thinking of driving the Rubicon, and you should be thinking about driving it, I'm particularly fond of my Blazer's system: 38" tires, 5.13 gears, 5" lift, 1" body lift, a locker in the rear, hydro assist steering, and stout sliders. I came through with little more than a scratch. This is the first time I've wheeled with hydro assist, and it is AMAZING. I'd say it is as valuable as my locker. I'd like to do a selectable front locker too, at some point, but didn't need it. A Blazer with smaller tires could do it - probably even at stock height with a locker - but you'd come out pretty bruised. I think sliders are a requirement.
I drove this trail for the first time last year with a couple of CK5 guys, a local Jeep friend, and a number of folks from Alberta (Russell and his buddies.) Last year we drove the trail east-bound from Loon Lake.
Info on that trip HERE.
I went with two local fellows, CK5er "alexsdad" and a Jeep friend of ours. This year, as we were headed toward the same trailhead, we found out via a highway sign that the HWY 50 was closed due to a forest fire and we wouldn't be able to access the Loon Lake trailhead. I was pretty disappointed, and concerned about going up Big Sluice (3rd panel from the left, above) because I don't have a front locker and Big Sluice has some big boulders. But, it was our only option, and in the end I prefer the west-bound route.
The first several miles from the west-bound trailhead to Overlook Point is fairly easy, technical, and terribly bumpy. But the ride is worth the view!
It's a big cliff-like drop off that gives you a view of the valley that the first half of the trail follows. In the map, you'll see Cadillac Hill, which drops down along the cliff edge to Rubicon Springs. Here's alexsdad and his wife and daughter at the overlook:
Rubicon-1 by colbyjstephens, on Flickr
This is a pretty typical obstacle on Cadillac Hill: Lots of narrow spots (often narrower than this), with a steep drop off to one side and big boulders to get you off-camber. My beautiful bride walked about 2/3 of the trail and was my photographer. She did a real nice job!
Rubicon-4 by colbyjstephens, on Flickr
Rubicon-5 by colbyjstephens, on Flickr
Rubicon-7 by colbyjstephens, on Flickr
Another common obstacle on that descent, of which I have no pictures, are terribly tight squeezes through trees - wherein you have about 3" of clearance on either side of your rig combined with an off-camber situation.
At some point on Cadillac Hill I heard a nasty bang, but assumed it was just my sliders or frame nailing a rock. When we got to the bottom of the hill I heard my front driveline clanking against my transmission crossmember. It turns out that I broke the rubber transmission mount. :doah:
Fortunately, at Rubicon Springs there's a camp manager with a generator, tools, etc. Rubicon Springs is actually a really well developed camp with a cabin for the manager, outhouses, a community area, rope swing into the river, etc. So, I went over there and dropped my transmission crossmember and clearanced the location where my driveshaft was hitting and then used a ratchet strap to clamp the transmission in place - to keep it from flopping around. Here's a picture of it after we got off the trail - notice that it did end up ripping, but there was enough friction between the rest of straps that it held it tight enough to get me home:
Rubicon-139 by colbyjstephens, on Flickr
I also sprung a leak from the connection between my power steering overflow reservoir and pump. Some over-engineered use of duct tape took care of that leak. And we were back on the trail:
alexsdad going down a big rock face after Rubicon Springs:
Rubicon-10 by colbyjstephens, on Flickr
Here's my friend at what I consider the beginning of Big Sluice. A picture of his vehicle gives better scale for the size of the boulders. Of the whole length of Big Sluice, this first couple hundred yards was probably the most challenging. As many of you know, photos of this sort of thing often don't indicate how steep the hill was. But, this incline is such that you're staring at the sky the whole time.
Rubicon-13 by colbyjstephens, on Flickr
Going up the same area, a great example of when hydro assist steering is of critical benefit:
Rubicon-14 by colbyjstephens, on Flickr
Another tight sqeeze:
Rubicon-15 by colbyjstephens, on Flickr
Rubicon-18 by colbyjstephens, on Flickr
After making it through the first section of Big Sluice, there's a real sharp turn where you have to squeak around a big tree. It's got a big drop-off on the passenger side, and of course, it is uphill and off camber. The pic doesn't do justice to the awkwardness of this obstacle.
Rubicon-19 by colbyjstephens, on Flickr
And it's a big tree:
Rubicon-20 by colbyjstephens, on Flickr
This was about a 4' wall, and it took us a bit of time to find the right line for the job. My friend's Jeep was first, and due to his short wheel base and being the first-up-guinea-pig, it took a while to find the right line to get him through. The Blazers were a bit quicker to get through thanks to the long wheel base.
Rubicon-21 by colbyjstephens, on Flickr
Feeling pretty good about how well things were going on the uphill attempt at Big Sluice:
Rubicon-22 by colbyjstephens, on Flickr
This is a picture of the final stretch of Big Sluice. You'll notice the size of the boulders next to my buddy's Jeep, for reference.
Rubicon-23 by colbyjstephens, on Flickr
Tight uphill squeeze, even for a Jeep.
Rubicon-24 by colbyjstephens, on Flickr
More to follow...
Full width axles barely sneak through:
Rubicon-26 by colbyjstephens, on Flickr
And then you move into a tight squeeze around another tree:
Rubicon-29 by colbyjstephens, on Flickr
Having completed Big Sluice, it's a bumpy ride with a few big boulders the rest of the way to Buck Island Lake: Our destination for the day.
Rubicon-30 by colbyjstephens, on Flickr
Sliders are key:
Rubicon-32 by colbyjstephens, on Flickr
A final look down into the valley before reaching Buck.
Rubicon-33 by colbyjstephens, on Flickr
Our campsite at Buck.
Rubicon-34 by colbyjstephens, on Flickr
Buck Island Lake is fed by an awesome system of waterfalls from another lake just south of it. The inlet is off in the distance behind the dog.
Rubicon-35 by colbyjstephens, on Flickr
Here's my bride filtering water for cooking/drinking.
Rubicon-38 by colbyjstephens, on Flickr
We camped on the section of Buck where Willyswanter's memorial is located:
Rubicon-41 by colbyjstephens, on Flickr
We took a day off of wheeling on Wednesday. Due to a communication error, alexsdad didn't realize we were sticking around for an extra day and had to drive out alone on Wednesday. He made it out just fine, and there were tons of folks on the trail that day to help if needed.
So, we took the day to explore on foot and do a TON of swimming. Here's one of the waterfalls where we spent a ton of time.
Rubicon-45 by colbyjstephens, on Flickr
Rubicon-47 by colbyjstephens, on Flickr
There were rocks on which you could stand under the falls:
Rubicon-52 by colbyjstephens, on Flickr
The water was nice and warm, and great for swimming. So, we kept exploring upstream falls until we reached the other lake.
Rubicon-55 by colbyjstephens, on Flickr
Rubicon-56 by colbyjstephens, on Flickr
Zoe the Dog is always ready for a good swim.
Rubicon-60 by colbyjstephens, on Flickr
Rubicon-65 by colbyjstephens, on Flickr
Rubicon-67 by colbyjstephens, on Flickr
We found a spot deep enough in the waterfall pool for jumping. It's mostly too shallow, but for this one spot.
Rubicon-73 by colbyjstephens, on Flickr
A view of Buck Island Lake.
Rubicon-74 by colbyjstephens, on Flickr
We spent hours trying to make a 150' zip line into the lake, but we had brought a dynamic climbing rope which stretched too much - and we never could get it taught enough to hold my 210 lbs. One of the 90 lb kids was able to get about 1/3 of the way across before his feet hit the water. Next year, we're taking a static rope.
Rubicon-75 by colbyjstephens, on Flickr
Claire was able to get farther than me (I kept crashing into the rocks... and they kept using me as the guinea pig. :doah:)
Rubicon-78 by colbyjstephens, on Flickr
On Thursday we started to head out. Going around Loon Lake there are a lot of off-camber situations that feel pretty tippy - and it got the better of my nerves. But, we made it through just fine.
Rubicon-79 by colbyjstephens, on Flickr
Rubicon-80 by colbyjstephens, on Flickr
Rubicon-82 by colbyjstephens, on Flickr
Rubicon-86 by colbyjstephens, on Flickr
We stopped to let Zoe cool off near the dam.
Rubicon-87 by colbyjstephens, on Flickr
Rubicon-89 by colbyjstephens, on Flickr
After leaving Buck, there's a LONG side-hill climb with incredible vistas back toward Buck Island Lake.
Rubicon-93 by colbyjstephens, on Flickr
Rubicon-95 by colbyjstephens, on Flickr
Rubicon-97 by colbyjstephens, on Flickr
Rubicon-99 by colbyjstephens, on Flickr
More of the climb.
Rubicon-101 by colbyjstephens, on Flickr
Rubicon-102 by colbyjstephens, on Flickr
Rubicon-103 by colbyjstephens, on Flickr
Rubicon-104 by colbyjstephens, on Flickr
Here's the top of the hill.
Rubicon-106 by colbyjstephens, on Flickr
Rubicon-108 by colbyjstephens, on Flickr
Rubicon-110 by colbyjstephens, on Flickr
Another squeeze.
Rubicon-112 by colbyjstephens, on Flickr
Rubicon-113 by colbyjstephens, on Flickr
We got out here to watch some Jeep guys doing Little Sluice. That would've been a fun obstacle, but they were a big group and were going the opposite direction. We would've been waiting around for at least an hour before we could've started down it.
Rubicon-118 by colbyjstephens, on Flickr
More boulder climbing.
Rubicon-120 by colbyjstephens, on Flickr
Now, don't get me wrong, the Jeeps do GREAT on the Rubicon. But, you'll notice here how the short wheel base can get a guy hung up sometimes. My friend has lockers front and rear, and made it over this rock with no problems once he locked them in.
Rubicon-123 by colbyjstephens, on Flickr
Close clearance on the side hill.
Rubicon-125 by colbyjstephens, on Flickr
Rubicon-126 by colbyjstephens, on Flickr
Rubicon-128 by colbyjstephens, on Flickr
Rubicon-130 by colbyjstephens, on Flickr
Nearing the end of the trail at Loon Lake.
Rubicon-131 by colbyjstephens, on Flickr
This is where we did our zip line. It was tough to get it tight enough because the tree across the dam was flexible though.
That waterfall is a lot less gnarly than it was a month ago! It looks like it's probably 10% of the flow that we saw. Hopefully we make it back out there this season. There was no way you could swim in there without drowning lol. Don't think we got any good pictures of the waterfall itself.
Did you guys get to use the rope swing or were you too busy? It was crazy how warm the water was when we were there.
I didn't get to do the rope swing because I had to fix my truck while we were at Rubicon Springs. :( I was bummed. Everyone else spent a bunch of time using it, tho, and catching crawdads and generally doing things way more fun than what I was doing. :D They did comment on how incredibly warm the water was there. The water in Buck was pretty dang warm too - though my friends said it was cold by comparison to Rubicon Springs.
I remembered you had said you did your zip line at the dam. We wanted to try to make a real long one, and thus our unsuccessful endeavor. :haha:
Looks awesome!
I was walking the trail from tahoe to observation point on Thursday. Would have been funny to see you guys up there :waytogo:
Im headed up thurs morning to go tahoe-loon as well. Hopefully i can hit old sluice and little sluice
