Ryoken green zinc primer arrived
76zimmer
Flyin Rat
Staff member
Moderator
Kzoo, Mi
it was mentioned in Pauls thread about a shortage of the primer.... I ordered 10 cans, they said it was backordered, but it arrived 2 days after my paint order... here is where I got it for 8.22/ea
boatersland discount marine
http://www.boatersland.com/moe025472.html
thanks for the reminder.. I need to email that place I ordered mine from...
I panicked when I heard it was being phased-out..... And ordered 12 cans from the only place that claimed to still have them in stock.
It took 3 weeks. And I was starting to think I got scammed.
The box arrived yesterday! :saweet:
-G
no sign of mine from PBS boat... sent em an email today...
That's where mine came from..... They don't communicate well. IIRC you ordered a couple days after I did. Yours should be imminent. :waytogo:
-G
Must be some good stuff.
Yep
Although I have had issues with the nozzles plugging up
I then resort to soaking them in thinner
I'm assuming that this high zinc primer has good anti-rust properties?Do you know of another primer that is almost/just as good?
Is it going away, or was there just a shortage?
Could this be your EPA hard at work to block anything good?
it's sort of the best self-etching primer you can run.. sort of... the 2-part catalyzed zinc washes are... this is an air-dried version rattle can.. obviously a million times more user-friendly, certainly not the quality of the 2-part.... but a happy medium for the weekend warrior...
it's purpose is not rust, it's adhesion.. it is designed strictly for raw metal.... initially alum..... you pretty much have to use it for that, but the properties that make it work well there, help just the same for steel.... tho, when used over clean raw steel as part of a quality coating system, zinc, uro primer, quality paint, it certainly aids in the corrosion durability...
really the next best etcher you can probably run is a modern epoxy..... which is what many resto guys have gone to.. they stick pretty well, and have come a long way in their sanding friendliness.. I still prefer a uro for sanding, thus it's what I run over the zinc, and skip epoxy altogether... you CANNOT put epoxy over the zinc chromate... but once the zinc washes go away, the epoxy will be the choice... albeit, a big drop in user'friendly as epoxy is pretty much a gun only 2-part deal..
if the zinc chromate goes away, I'll probably try to run a 2-part for as long as that is still on the market.... albeit much more expensive and a pain to do...
here's a thread I did on the zinc chromate a few yr's back if your bored..... https://ck5.com/forums/threads/zinc-chromate-tech.262999/
well, the scare is on.... they've been trying to get rid of anything with zinc for decades now... all our marine suppliers are showing it as discontinued, which is an ominous sign being that's where it get's heavily used...
that applies to anything with a catalyst.... go squirt water-based and get back to me on that....
Glad I was able to use it for my restoration...it was good enough for WWII aircraft...been in use for decades...sounds like tree-hugging EPA crap to me.
