ryoken submitted a new Build:
Ryoken's 89 Crew Cab Tubebed build... aka Mutt....
Read more about this build here...
page-4 Virgin delivery!
page-8 Wood flat bed (through post 240)
page-14 Bravada temp filler neck
page-16 Alternator upgrade from 12SI - including link to alternator upgrade parts
page-21 fresher doors
page-24 New ignition parts, also pg 24 THE hood ornament discussion
page-29 Start of BBC upgrade talks
page-42 Flatbed planning
page-44 How to change brake fluid, new lift parts, start of sheet metal redo
page-49 Ryoken Red
page-65 more lifty parts
page-66 start of lift and cross over
page-77 the Mallard has landed
page-89 New grille
page-108 Back half paint
page-118 tube stuff drawings and planning for tube bed
page-123 Tube!
page-136 midpoint of tubing work for the bed
page-137 new wheels, hitch plate, parts n stuff
page-139 14BFF w/ discs from Kert
page-142 37 inch tire delivery
page-172 Spare tire mount finished
page-181 final revision on tail lights
page-187 Hitch tie ins, start of Fab table planning
page-195 Start of alum framing supports
page-199 Fuel fill tube for new tank/planning
page-204 Completed tube bed with paint, on chassis end of page
page-213 Tail lights and drivers rear corner panel in
page-216 How to radius bend flat aluminum panel
page-225 First drawer in!
page-236 New welder, new door for side tool box
page-242 Kennel Talk, start of fuel tank doghouse cover build on pg 244
page-250 Finished tank doghouse (transition to driver’s side lower box, more kennel plans)
page-268 Fang cutting and front bumper mockery
page-273 Tube bed steps
page-289 Puppy sighting!
page-296 Front bumper uprights (finished fab on pg 300)
page-305 Malakai
page-316 Light bar shopping
page-327 Dizzle donor, box/drawer redo
page-335 finished drawers
page-340 Down the dizzle rabbit hole
page-344 rear wheel wells panels (excellent view of panel mounting)
page-350 The Dirty Dodge comes home
page-356 Flag pole holders
page-361 Start of battery tray
page-370 Dizzle paint/clean prep
page-392 Bed door seals, tool drawer lighting, battery drawer wiring
page-400 Hose/cabling tie down link
page-405 Build your own wiring harness, wire chase/Delrin, continuance of battery cabling
page-408 Installed pull out tray/videos. Then inverter, rear winch & wiring
page-412 Switches in the ashtray, start of Dash reconfiguration
page-416 Death Proof duck with Death Proof eyes
ok, couple weeks left here.. the rig should get picked up monday, maybe to me by next weekend or so... but I need a place to start rattling out plans, parts, etc, so they don't get forgot...
Here's how Mutt is sitting out on the west coast at the moment awaiting transport......
couple new things waiting for her...
slightly different approach than previously mentioned... I am going to be doing a quickie, easily removed temp wood flatbed.... super simple, got this flat black stuff at work I'm gonna douche it real quick... weekend project out of the gate...
i came to the conclusion , that with material costs more than likely in the 2 to 3 grand range with the fuel tank and probably a good 200+ hrs initially for fabbing, it may be aug before the tube bed and fuel tank setup in back is able to be "run"
might as well make the small effort to have the truck be reasonable looking for the po-po, my inspection guy, etc till the tube bed can be final installed... the wood bed will be easily removed or installed in 10 minutes, 4 bolt's... this way I can pull it off on a friday when i come home.. working on the bed, rear frame and suspension, etc, than slap the wood bed back on monday morn or something...
I'm definitely sandblasting from the cab backwall to the rear early on.. tarp and a sheet a ply to protect the cab... more than likely that'll be the first weekend project gig.. clean primed slate to start rear suspension and the bed from...
gonna need a couple tires for inspection... that'll be the first purchase when it gets here... actually i'm having the bed lumber dumped off at work next week... i should be able to bang out the structure and slathering it with paint in a day... mount the next day... first real fab will be the rear x-member and tube bed mounts....
once all the tube bed materials are paid for, I can give Kert a jingle and start investing in the hangars and custom rims... I've already determined that there are a few certain things the K5 will have to temp donate till i can repurchase later.. some of the x-over stuff, SRW hubs, a few other lift components...
that needs to be done if I'm gonna fasttrack Mutt here to toughication....
as some may remember the...
page-49 Ryoken Red
page-89 New grille
page-123 Tube!
page-305 Malakai
but nonetheless a purpose.
Cant wait to see what you do
