in addition to the questions above, what type of primer should I be using at this point...the self etching or the high build or some other primer....I was scared to use the zinc chromate because you said the duraglas doesn't like it.
what should the consistency of the filler be as I am spreading it? It seem too dry to me...but I am afraid to put less hardener in it becase the last time it never dried...
and what grit paper should I be blocking and cutting the filler with? Can I use the random orbit or do I need to block sand it?
