s10 blazer on a full size blazer frame qustions?
79mudder
Bonesteel
i got alot of questions. lets start by steering . ive read on here a while back about useing it from a astro van? how about front fender clearence [fire wall] will i have to extend the fenders? by the way this is a four door s 10 blazer. all the info you guys got will help me decide to do it or not. any pictures will help too. thanks.
the best thinkg to do is start measuring, the measurments are pretty close between the frames. One question though why ditch the s-10 frame, it is already boxed in on the front half and stronger than a k-5 frame, if you are looking to go sfa it is not to hard to do that on a normal s-10 frame
its just that i got a s10 body setting in the back yard with absoulutely no rust and paint aint too bad, just thought it would be differentand look realy cool. i think it would be easier than doing the front axle swap and putting the motor in the s10.
www.sky-manufacturing.com offers a full width axle conversion kit for the front that the guys at www.s10extremist.com are using alot. its based off of their full width conversion for Toyotas. take that, along with a Dana 44 or Dana 60 from a leaf sprung late 70s Ford, and you should even be able to use the stock transfer case. the rear suspension is pretty easy to address. a springover conversion along with a shackle flip should get you at least 8" of lift for the back. with aftermarket springs, the sky is pretty much the limit.
You can't do a shackle flip on an S10, they're not a tension shackle. It's already set up as a compression shackle. A spring over conversion gave us about 7-8" of lift by itself with our S10 though.
The astro steering box is only if you're using the S10 frame. We're using one in the S10 that we SAS'd and SOS'd. We moved the axle forward about 5", so we won't be getting firewall clearance issues. There's some pics HERE.
Mine is six lug. :p: Then there's the minor difference of about 13" of lift...
