I wasnt going to spend the 150.00 on them either..lol. The plastic has worked fine in the past, But i need to change my steering arm and am going to dig in. I figured id buy the crane eliminators and the bronze bushings since i just did axle seals, gears, bearings, axle joints, wheel bearings, seals, longfield spindle bushings, rotors, calipers,pads, lockout hubs, gaskets, spindle nuts etc...i figured y not..thats the missing link. The only pieces not changed is the king pins them selves and they looked pretty damn good.
.....Im not sure tho should or will i need the extra washers they give you for the eliminators. Prob disconnect all steering linkage with the knuckles and make it snug but not tight to turn.
Saying all that will be done that makes the 60 and the 14 bolt new now too. Since i just rebuilt the 14 bolt and the only old piece in that are the hub bearings....i even changed the yoke..lol.
