Well the Grinch may be alive but he is bleeding!! And a slight miss on the pass side.
It's late, I'm pissed and Mr. Murphy needs to leave me the fock alone.
On break in I had a few small oil leaks on the fittings of my cooler. A small coolant leak. No biggie.
After it was shutdown and we pushed it back in the shop (Tranny wasn't filled all the way and the controller needed programming) I noticed some oil dripping around the starter area, not much just a few drips on the floor.
Well tonight we fired it up to adjust the timing and play around with the fuel injection system. After it was running between 900 and 1200 RPM for about 5 minutes I noticed some dripping from the starter area. Looked around and it was
NOT coming from the valve covers.
NOT coming from the back of the intake either. After running for about 15 minutes or so there was a puddle on the floor around 8-10".
It sure does look like it's coming from the head/block area. Could the head gasket be bad?
Major leak #2. Moved on to topping off the trans. Slight leak on the cooler. No big deal. As I added more fluid I noticed a leak at the back of the trans.
Major leak. We decide to pull the transfer case. Some Dumb Ass (me) only sealed one side of the clocking ring. Another problem that I noticed was the studs on the clocking ring pushed into the transfer case as the nut was tightened. Fixed that. Fired up the new Miller 211 and tacked them in from the back side. Cleaned up the clocking ring, got out the tube of Right Stuff and coated
ALL surfaces. Problem solved!!
Problem: On the same side of the oil leak there is a slight miss/stumble. Since I'm running some hillbilly (no offense, Southern Brothers) exhaust you can really hear it when you stand in the back.
The cooling system also needs little tweaking. The dual sensor I used for the windstar fans is not working good. The first fan doesn't come on until about 200 and the other fan doesn't even come on. I did however run some temporary grounds so I could bypass the sensor to get the fans to come on.
I let the Fuel Injection stay in self learn mode. It's running a little rich. All plugs a little black. I will be checking for vac leaks and maybe some of the preliminary settings are a little off.
Sorry for the long post and rant but I do feel better after typing it all out.
Just need to fix one problem at a time and move on. There's still some snow to go flying through.
Sorry no pics tonight/this morning.
