bigred88
Now let's talk tactics. First, consider what would happen if the truck burns to the ground- what else is nearby to burn? Are you on a trail in the desert or are you in your driveway right next to your house? If your truck is running in your driveway or shop, best choice is probably drive into the street (if it is safe to be in the truck for another 10-15 seconds), accepting more damage to the truck in return for not burning the house down. If you're in Moab, just stop, take the truck out of gear, and turn it off.
I say take it out of gear because I went to a early 70s Ford pickup that was burning, just a small carb fire that had spread but still contained under the hood. The truck was left in gear, and as wires melted the starter shorted and engaged, and the burning truck began driving forward on the starter for a few seconds. So take a second and take it out of gear.
Don't discharge your extinguisher without a clear shot at what is burning. Shooting a dry chem through the grille may have put out a few fires, but it's more likely to waste your extinguisher because the agent has no direct path to the fire. If your inner fenders are no longer there, through wheel wells is a good first attack. If they're still there, you'll face the same problem as shooting through the grille.
Most of the time, you will have to open the hood. This is best as a two person operation- one to open the hood and the other ready to discharge the extinguisher the second the hood is open. The fire is extremely unlikely to suddenly flash or explode the second the hood is opened. It will however start growing much faster. I wouldn't be afraid of opening the hood, but I also wouldn't do it without having an extinguisher immediately ready.
Fact is opening the hood will give you the most direct (and therefore effective) shot at the fire. Any other options are risking wasting your extinguisher and not using it to its fullest capability.
