Well, thanks for your input guys! I get paid tonight and will be placing an order for ARB lockers for both axles along with a set of 5.13 gears. That's gonna hurt the pocket book a bit haha
One of the reasons I want an ARB rear is for cutting brakes to work, not really in the rocks in the dunes.
So are most people liking the Detroits because they're automatic? From what I understand it's locked on throttle and open off throttle. So what if you're turning and accelerating?
Eric the cutting brakes should work fine with a detroit if I am not mistaken, the outer wheel would disengage and turn faster, allowing the inner tire to remain stationary with the ring gear.
Were you thinking a truetrac for the front of your jimmy, or a clutch type posi like an eaton?
The detroit works like K5dreamer said, it's a matter of torque direction, not throttle position. Think of it like a ratchet with a cam as the flip lever. The ratchet is always on, it can only switch directions. The ratchet will never allow either tire to go in the opposite direction of the torque applied. The torque operates the cam to initiate which way the ratchet works. So under acceleration either tire can spin faster than the ring gear(not both, or the cam switches directions), but none of the tires can spin slower. So you have full power to both wheels, yet can turn around corners when you want without binding.
Under engine braking it will allow either tire to spin slower(not both), but none faster, because the torque is reversed (not wheel direction, but wheel torque is what "flips the ratchet lever").
So under power around a corner, you are driving the inside tire, the outside tire is freespinning faster. But the moment you apply too much power, the inside tire will spin, and once it catches up to the outside tire (very quick), it will lock together because it cannot let either tire spin slower than the ring gear. Under engine braking it's the opposite.
Make sense?
Makes perfect sense once I read that a few times over (I'm a visual/hands on leaner). So why do you want to stay away from a Detroit in the front on Icy roads?
Would the same be said for the rear then? I live in Denver so driving on icy roads in inevitable.
well... i think that's up for debate. what I'm getting from all this is that on ice, it really doesn't matter, you're screwed...
maybe tone it down a bit?
Makes So why do you want to stay away from a Detroit in the front on Icy roads?
