serp belt system
what about the lines to the ac comp? the differ right? So are custom ones needed or??
Yes he will need the lines made anyway. When I do mine I plan to just take the mounting flange in from the new compressor and have EVCO make me a new set. But, I am also replacing the stock R12 condenser with a newer bar type parrelel flow unit to improve the cooling at the vents. The only downside I currently have is that I need to have the R12 pulled out, since mine is still charged, unconverted, and working, and I don't plan to vent to the atmosphere.
If your current alternator is a 12SI and the new one is a CS130 there is more to it than just splicing the plug since the CS series alternators require a "sense" signal for them to start charging.
