I have my rear shackle flip on and am having issues with finding the right shock / mounting for my needs. I am running a 52" spring with a 4.5" shackle. Currently the only weight on the rear is a 1/4 tank of fuel a spare tire and the interior is mostly stripped.
Thanks to all the reasearch that Dueling has done on the fox 2.0's. I think I am going to use his idea and go that route. It should work out well for my truck. I am unsure on how to mount them. They look like they take a different type of mounting or bushing than standard shocks? Any advice?
Originally I was planning on running the 12" shocks in the factory postion. However, that limits my travel to 3.9" up and 6.85" down. After talking with Chris and Stephen at ORD I believe I need to go to a 14" shock in order to have any uptravel. If I go with a 14" shock I need to come up with a new mounting system.
I was wondering about using the DIY4x Shock inboarding cross bar so I can run a 14" shock. Would this work out well for me and allow me to use my full travel potential?
The option Stephen had suggested was reloacating my axle mounts on my shocks and tipping the front of the shocks foreward in order to gain more shock clearance. I do NOT want to cut into my floor at all.
Any advise or guidance is much appricated. I can get pictures (not much to see) if needed.
14" travel shocks are 35.1" expanded and 21.1" compressed.
My right shock eye to eye is 23".
My left is 24.25" due to the mounting bracket being on top of the frame.
