My thoughts about flushing a transmission is it "might" cause an issue where none existed...not so much for dirt & debris being "loosened up" ,but the flushing machine itself,and the fluid in it--is it "recycled" fluid and simply filtered out and put back in,or is the new fluid separate from the stuff being sucked out ?..
I'm not familiar with them or how they work,but if they consist of a "closed loop" system that supposedly puts fresh fluid in while the old is being flushed ,how does the machine keep fluid from other vehicles it was used on from mixing in with the new fluid.?..
Seeing there is no less than a dozen various types of ATF and using the wrong one can cause issues or damage,I wonder how many transmissions needing dexron end up getting a mixture of various other fluids,due to some being left in the hoses and pump on the machine..
The most I've done to my automatics is drop the pan,replace the filter,make sure all the valve body bolts are tight,and put in the correct amount of the proper ATF and call it good..
I've found several loose bolts on a few TH350's and tightening them cured a delayed engagement after a cold start and whining noises on one car I had..I found several bolts in the pan on a K-10 Suburban I bought with a "blown tranny" ,after I put them back in and tightened them,it drove and shifted perfectly again!..
I'd have preferred to get rid of ALL the old fluid,but the method of removing the cooler line usually results in a massive gusher that's tough to control when your working alone,and you'd need like 20 quarts of fluid..which ain't exactly cheap nowadays..
I've been reading up on other forums about people who have been using tractor hydraulic/transmission fluid in older non-overdrive automatics like TH350's and TH400's,and they claim it reduces the stall speed of the converter some,and withstands higher heat better,and its basically the same thing as dexron without any dye to color it,some specs on it even say it can cover the uses where dexron is required....
Seeing you can get 5 gallon pails of it for about $25,its a lot cheaper than dexron,and farmers who live out in the boonies who used it when that was all they had handy,say their trucks haven't had any issues with the transmissions..even some racers use it exclusively instead of dexron..I've been tempted to try it,but I don't want to find out it wasn't good enough and ruin a transmission to save a few bucks on fluid..but if it IS better,its a bargain..
