Should I move the hanger back?
Gotcha, didn't think of that. And u have the 3" block under your steering arm?
yes, needed the block for the old spring setup,it wouldn't come off when I swapped springs so it stayed.
Oh yea yours clears by alot. I don't have the block but my drag link barely clears the springs. I can slide my hand between them flat.
check for clearance @ full stuff on driver side with passenger side @ full droop, If steered full driver side it may hit spring....
I think that came out clear as mudd lol:D
Yea I think I might end up buying the block. Sux I had one but sold it to my bro for his truck. It is really close. Is your drag link str8 across? Or does it have a couple bends.
Ok, yea maybe I'll look into getting the block. I really appreciate the pics and the help. Hopefully I'll see you at blazer bash
Just PM me if you need any more pics. Oh, and you are going to be blown away by how much those suckers flex. Just be sure to add the bump stops. without them the front will flex so much that the rear springs wont get to flex.
I plan on going to BB every year I can....I'm sure I'll see you there.
OP: you running the B52 brackets? Easiest way to move the springs forward some. Like Chris said, don't be concerned with the draglink angle front to back, it can be forward without it driving funky. Just make sure you have the bent like Chris's with that high a lift you've got.
Block it, move springs forward, bump stops, shorter shackles. :) Be happy
Yep sure do, that was my biggest concern was the draglink not lineing up and drag link hitting u bolts. But now that the truck is baring almost its entire weight. It actually pushed the axle back about a inch
