I like diesels,but the 6.2 gets tiring to listen too,you feel like your driving a tractor or backhoe instead of a truck,and somehow,to me it makes a short trip seem a lot longer...
I normally head up to the mountains for ~10 days, each day is probably spent gaining 5-10000ft, no idea on mileage, it varies. But under those conditions I'm lucky to see 10MPG all day. As it is, with the 100 gallon spare tank I've got plenty, but that's now because I'm the only one running gas. When more rigs ran gas, it was just about right. As it is now, all the diesel guys have to run back out at least once to fill up. Depending on conditions, it is a run you might not want to do if you had a choice.
But this is just shop talk now, it's pretty obvious the 6.2 is not a wonder motor. The 4BT is quite tempting (30MPG? 900 mile range?? drool) , but I think that opens up another can of worms that begins to approach the "just forget the idea" zone.
I suppose if the right one fell in my lap I'd be inclined to take it. All my emotional attachment can be unbolted.
A 6.2 is NOT a Detroit.
Actually, it is a Detroit diesel engine. GM didn't make them.
I think what Martin means, in his typical excessively wordy styleis that it's not a "real" Detroit Diesel in his mind.
-- A
-- A
I think you are geared too high to see good MPG/range with the 6.2/6.5L family off-road. It would do well on the road though.
My '79 K10 with 6.2L/SM465/NP205/10b/14SF/285-75-16 tires and 4.10 gears would run 3-4 days on one 20 gallon tank wheeling in Naches. Way better than the stock carbed 350 that made it about a day on the same tank.
They should have based it on the 5.9 Cummins, then it would have been worth a damn.GM based the 6.2L diesel on the Detroit 8.2L fuel miser.
I'm talking about lack of power hurting the offroad performance, thus hurting range offroad. 3.42s are good for high speed cruising, not climbing steep hills in the mountains.Too high? Why would you want lower gears with a 2200RPM cruising speed? That's already excessively fast for a 6.2...![]()
They should have based it on the 5.9 Cummins, then it would have been worth a damn.![]()
