This has been a long time coming. I'm more concerned about range than most anything else with the truck. I should have built it as a Diesel in the first place, honestly.
The most I tow is (and this is high) 3000lbs, and that is flat ground scrap runs, which I do maybe twice a year. Trailer weighs 500lbs, I use it perhaps 10 times a year total, 1500lb average weight. Only mountain/hill use truck sees loaded down is hunting season, and that's up and down once.
Truck runs right about 2200RPM @ 65MPH as-is, and I don't cruise over that MPH. My thinking is that the final drive ratio is about right for a diesel now. I do enjoy a nice burst to pass someone, but I could learn to live without that if I had to.
I might put 5000 miles on it per year. And that's probably higher than reality, I never pay attention to how far I go. It's so little that I don't put gas in it before I park it, so I don't end up with bad gas.
I'll "lose" quite a bit of money trying to get rid of all my spare TPI/gas engine parts. I've got a LOT of spares I picked up because the price was right. It's money already spent, so I'm not really losing anything that isn't already gone, but I would not look forward to knowing I'm taking a loss on brand new stuff, let alone tossing it because there is no demand. With the LS stuff getting so popular, I'd probably be dreaming to think I could get $750 for the complete TPI motor out of the truck now, even if someone could test drive it first.
Judging by Craigslist and my location, pretty sure a .mil 6.2 could be found pretty easily, and I saw a 6.2 running/driving Suburban for $1200. Not sure if more power is what I need if I'm worried about best economy. Of course, by the way most people take care of stuff, I'll need a new radiator at least, and I'm betting the huge ones are still $400+.
It doesn't sound like there is any pro or con between the 6.5 and 6.2 in terms of durability. Both had issues apparently, but I would think a low mileage 6.2 would be pretty likely to last my lifetime.
Economy I'm unsure of, I assume the 6.5 uses more fuel. I'm not scared of electronics, but again, unless there is a marked gain in reliability or economy with a later 6.5, probably not worth a tradeoff in range.
I've driven 6.2 equipped rigs a fair number of times, but they weren't a manual, I wasn't towing or climbing hills, and/or they weren't one of these trucks. Gearing is different, weight is different, etc.
My thought process is that the 6.2/6.5 swap is pretty much a bolt in with a donor rig, and I will get 28% better MPG than I do now, if the engine will do an honest 25MPG, which I've heard is possible with the right setup.
What do any of you diesel owners past or present think?
Both goals are achievable, but it seems like a lot of work compared to simply bringing along a barrel of diesel to help your buddies out.
). It tows very nicely, and I have twice tipped the scales above 11,000# while trailering, but for normal driving around it's just not nearly as pleasant as the highway-geared K10.
