Refilled all my propane tanks, got the ORIs charged up..that was a chore cause they were sticking (which is normal). 110 psi in the lowers and 280 psi in the uppers gets me to ride height if anyone is wondering..had to jack the truck up to ride height with the high lift, 2 jack stands and some wood. went for a ride around the block. drives and handles like a slot car...a slot car on cold 42s with 10 lbs of air..forgot how fast the orbital is too, remembered that real quick.....Got back and noticed I have no rear brakes....see I got a bunch of air in steering brake...can't get out with the hand held vacuum bleeder. I blew a wheel cylinder on the passenger rear at some point and it slow leaked over the winter..I replaced it last week but the leak musta crept up to the steering brake...almost took the steering brake out, but then harbor freight and the internet came to the rescue. they have a air powered brake bleeder..So harbor freight in the morning it is. 205 is making a clunking rotating noise in 2 high when you get off the gas. doesn't do it in 4wd. It was half a quart low on fluid.
Let it idle the entire time I was working on stuff (good hour) and then went for the ride. Temp never went above 190 and I put a 16 lb vent-able radiator cap on it.
