Shrunken Ned...
Lets put it this way. I will buy dinner, if both of you make it Moab, in your wheeler this year. As in Horton and Ned.
I got the power brake booster/master cylinder mounted to the fire wall. Got the propane mixer mounted to the intake and to the go fast pedal. Air cleaner fits great. Put new plugs in the motor. Put new plug wires on. #6 was an absolute !@#$% cause of the wrapped headers. Had to use right angle plug connectors on #6 and #8. installed the oil dipstick. Installed the distributor.
I'm trying to put the new stuff on when I can so it looks like I'm making progress when I go out there and see it.
That is gonna be delicious
Best way to get stuff done just do something every day
nope, cant find solid plugs..plenty with holes but no solids...I'm gonna get some challenge coins and JB weld them over the holes.
got distracted today... spent some time installing capacitors on my HIDs in the Dodge. Now the computer will stop telling me my headlights are out :rolleyes:
Got the font pulley's all finished and the serpentine belt on. power steering pulley fought me the whole way. finally had to call in air support. Got the plug wires all cut to size, connected and installed.
My 700r4 is a full manual so I don't need or have the TV cable anymore. but I still have the hole, which needed to be plugged. after much thought, I bought a boat bilge plug and turned it down on my bench grinder till it fit the hole. works perfect
So i went back in the shop and started working on this POS again today. spent $900 on a pair of Beard T-1 super seats awhile back. waited 6 weeks to get them. spend all day mounting them to the suspension seat cage tubes I paid to have built when it was in the shop and once they were in it turns out they are too !@#!$ tall for the cage. Only way to use the Beards will be to cut out the entire floor and do mounts off the frame. I am so beyond pissed. and I also found 2 bolts in the transfer case mount the shop ghetto'd into the mount and then painted over so it wouldn't be noticed, which didn't help my overall outlook
woah back from the dead! any way you can move the mounts out or to the side to help with lowering it?? I cant visualize what your talking about.. sorry.
After getting some sleep and cooking a steak for lunch today, I'm not as angry as I was last night. I went back out and looked at it again. I have only been farting around with the drivers seat..I took a look at the passenger side and because I have the 203/205 flat bellied and clocked there is no chance I'm gonna get any suspension seat to work on that side..So its plastic seats or milk crates
