Times Welding
Registered Member
I am in the process of installing a set of deep tinted sliding windows in my '87 K5. It had deep tinted solid glass from the factory, and I miss the sliders like I had years ago in another K5. I have totally disassembled the window assemblies and have powder coated the frames and wing window brackets gloss black. Hopefully that will make the frames blend in better with the deep tinted glass. I have located replacement latches, a Southco product (McMaster-Carr part number: 1891A49. 10 pack of both halves for $14.54). I have located the felts for the vertical divider. Any residential glass shop should have that material in bulk for about $.50/foot. I think LMC truck has the rubber trim piece that goes in the slot in front of the fixed glass pane, outside of the sliding pane(part number 36-6196 for $18.95 each). My question is where can I find the proper flocked rubber channel for the sliding glass to slide in? I build street rods for a living, and have a pretty good network of suppliers and I have found nothing that is the right size. I have found one piece still on the shelf at a GM dealer, and for an arm and a leg, I can have it. But that only does one side. Does anyone have any ideas?
Thanks,
Doug
Thanks,
Doug
