Got an appointment at my friends shop for next saturday for their best mechanic to check it out. Its a restoration shop that doesn't typically work on anything newer than 1985 unless its something special. The guy there wants to test it on the highway in 4wd to eliminate the tcase as a potential cause. While I trust him, I can't find any info about what the max recommended speed for a locked-in NP208 would be. Anyone know? I can usually get it to start making the rattle around 60mph. This would just be for a short stretch to see if it makes the noise.
Also, the trans started dripping from the input shaft yesterday, probably 8-10 drops worth on the ground since i parked it saturday night. This is with a fresh retainer gasket in place and the seal was replaced 3k miles ago. Was a little surprised by this... would it be an indicator of a sloppy input bearing?
The leak also seems to have cured itself, it hasn't left a drop since my last post.
