Don't get discouraged, this is part of building a truck...happens to us all in some form or another.
Rene
Rene
Well, I'm not sure if I fixed the problem yet, I still need to test the truck out. Currently I don't have it. I removed the oil pump and the pressure valve was stuck in the channel with a little rust. So I gave it back to my uncle and he gave me a new one. It's a high volume Mellings btw.
It's installed but still at the shop I took it to. They are doing a bunch of other little stuff as well. I wont know till Thursday cause I'm busy with some temporary work till then. If it's all good, it goes to the exhaust shop, then carb guy.
Here it's being loaded up, only 10ft from where it's been for the last year. Poor grass.
http://coloradok5.com/forums/attachment.php?attachmentid=114648&stc=1&d=1300026860
Are you talking about just that little "coupler" piece between the pump and distributer?
damn, I'll have to change the shaft myself or wait 2 weeks before they can do it. The truck will be moving Thursday to a couple different shops, I would think it should be fine for now.
Can I drop the shaft down through the dizzy hole?
Any theory why? I have a HV Melling now but haven't put the engine together yet.Negative, the shaft is made in such a way that it will not come out through the top when you pull the distributor. I would seriously get rid of the pump and put a standard pump in there. I've seen too many failures from SBC engines that ran either a high volume or high pressure pump.
Melling M55
Melling M55A
Melling M55HV
Sealed Power 224-4143
Moroso 22100
Moroso 22135
Canton #21-500
4x4high, Is it due to the fact that standard motors arent set up to have that volume of oil pushed threw them? I heard on time that its because it pumps the oil out of the pan faster then it can drain back down into it. So if you had like a seven quart pan, you are ok with high volume.
