so holley sniper feedback has me thinking . . . fire in the hole . . . BOOM !
That is better.
Actually, there is no reason he should have missed, he still has that pink machine.
Just more proof he doesn't drive it and I should send a semi to retrieve it from his garage
I've had my new summit cataloge sitting on the kitchen table open to the sniper just taunting me. My edlebrock carb runs like shit when trying do anything off road. I don't even have to be off camber. I know I can dial it in a little better but it would only be a little better so...... I mean......
I need to find a good step by step for idiots on this. You know one with everything from fuel tank all the way to the maifold, distributor(is HEI compatible) and ECU. I have never messed with tbi. I gota face my fears. It seems the master kit would be the wisest to get? It comes with a fuel pump and 20' of fuel line.
This is what I did with my fitech^^ way less noise and pumps last longer
I may sell my FITech/Boyd tank with aero motive stealth pump. Iay go back to a carb on my k5. It's cool if you like tuning electronics but I feel I could get better results with a carb even off road. Just a thought right now only bc I don't like tuning
Thought they tuned themselves?
@tenderfoot why go external pump ? ? ? louder / less efficent . ..
swap in the newer tbi tank and sender with acdelco ep381 pump like the rest of us .
This is why I said something. Really I just need to read a good build thread that addresses the questions I have. For some reason I'm thinking my HEI isn't going to jive? Am I right?
Why do you think that? Timing control can be separated if you want.
@Bent77 looked into using a GM HEI, not sure what was needed. As bagel mentioned already, the timing control is an option, I've done it both ways however I find those with the timing control run better.
I'll have to get back on bents build thread. I was was wading through it. I think I was almost half way. Just keep trudging through the trolling and I bet he has a write up on it in there
