If it's strapped the right way it shouldn't move.
I doubt the little tiny attachment points in a Subaru wagon are made to strap the weight of an engine in a crash, strap it all you want that engine my still kill you.
If the straps are done properly and you have the back seat as a second layer of safety, the engine shouldn't move.I doubt the little tiny attachment points in a Subaru wagon are made to strap the weight of an engine in a crash, strap it all you want that engine my still kill you.
The tie down points in the Subaru Outback's cargo area are typically rated for about 44 pounds each. It's important to ensure that any cargo secured to these points does not exceed this weight limit to maintain safety during transport.
Hitting a ditch or a wall is different from a panic stop, I know the laws of physics as much as you do, I never said it will hold in that situation. In a panic stop the tires lack of traction will allow the total weight to keep moving at the same speed.I don't care how well you strap down your engine. The laws of physics are against you with a sudden stop.
A 440 Mopar big block engine went through the bed and back of the cab when my FIL put one of my trucks in the ditch and stopped by hitting a culvert at 45 mph. He is lucky it went through the passenger side.
Still pissed about that one.I don't care how well you strap down your engine. The laws of physics are against you with a sudden stop.
Probably, are you referring to bolts that go in the front driveshaft flange? Most of the time they are not flanged bolts.I lost my drive shaft bolts that connect to my t case. I know I can get new bolts but they don't have a shoulder on them. Do you have any?
Hmm mine were they must have not been stock.Probably, are you referring to bolts that go in the front driveshaft flange? Most of the time they are not flanged bolts.
WA - OEM Bolts and Hardware
I have parted out nearly 20 trucks in the last 5 years, tossing screws, bolts, brackets, spacers, etc into buckets as stuff comes apart. If you need an OEM bolt, I probably have a few extra. Recently, I have been getting better at sorting them so I can find them when needed. $10 shipped minimum...ck5.com
Those bolts are standard 7/16-14 UNC x 1.0" long grade 8 hex screws that are fully threaded. The difference between a screw and a bolt is the washer like feature on the bottom of the head.Not flanged, but I assumed you meant shoulder bolts like Kenny has shown.
I don't know about 1/4", all my original bolts had about 1/8" shoulder.Had 1/4 inch of shoulder. I assumed to keep the thread from running in the holes.
And I agree I prefer having a shoulder and not having threads rub on the inside of the flange
Shank or shoulder? Shank is the unthreaded portion of nominal diameter. Shoulder is larger than nominal thread diameter. It is possible GM used partially threaded screws at some point in production, I just do not recall coming across any off hand.Had 1/4 inch of shoulder. I assumed to keep the thread from running in the holes.
Not in mechanical engineering terms. However, it is not uncommon for people to mix up names either. But google "bolt shank" and you will see it commonly being referred to as the nominal diameter unthreaded portion of a bolt/screw. Another term I have seen used is "body" in place of "shank".I thought it was the opposite of that.![]()
