Magikal
So what's the goto setup for steering columns? My Chevy tilt is about ready to die. It's been a good column with lots of use, a few different vehicles, several white knuckle holds....
Trying to decide whether to rebuild this one or just replace it. I don't need any of the goodies as I'm off road only. So no blinkers, horn hasn't been hooked up in years. Ignition is relocted into center console and i run a cable shifter also on the center console. But the tilt pivot pins are getting sloppy and the bearing at the end of the shaft is all but nonexistent anymore.
Easy enough to replace these items, just exploring other ideas/ alternatives.
