Steering wheel upside down after lift!
Eagle Driver
Florida
Got a Blazer, got a lift kit, got an upside down steering wheel :doah:
I am new to the world of K5's, and I just put on a 4" Tuff Country lift on my 87. Everything seemed to go well (still need to extend the brake lines), except when I jumped in the truck to fire her up, I noticed the steering wheel was upside down. Must've happened when I was messing with the steering arm and "that other piece it connects to".
How do I fix it?!? I don't want to take off big pieces, my arms are tired from loosening rust frozen bolts. Is there any easy way to disconnect the wheel and rotate it in the cab?
Thanks ahead of time!!! This forum was instrumental in me disconnecting the steering arm (3 pound hammer, PB blaster, and a six pack).
Also, wtf is bump steer, and how do I know if I have it? Ok, enough ?'s for now...
THANKS!!!!!
You changed your steering geometry so you will have to adjust it back to factory. Your drag link should have adjusters. Adjust it till your wheel is striaght. Bump steer is bump...oh ****(pulls to left or right).
1. losen the nuts on your drag link adjusting sleeve
2. Turn adjusting sleve till wheel is straight
3. go for a drive, see where wheel sits, if not straight pull over and turn sleeve some more.
4. repeat step 3 until wheel is where you want it.
5. tighten nuts on adjusting sleeve.
6. pat yourself on your back. :D
Just leave it like that, because soon you will be putting in a D60 with a zerorate and moving the axle forward again anyway...lol
That is why you go crossover then you dont have to worry about adjusting the draglink. Anytime you mess with the suspension you should align it. Wether you take it to a shop or if you do it with a tape measure you should always align it. Your tires will thank you.
Ira
Check out J.C. Whitney p/n AJT815939. I've gotten some good advice from this forum and would like to return the favor.
