1. Its hard to tell cuz everything is so covered in oil, rear spark plug wires "valve covers", and now i notice oil leak is directly under back of engine.
Think i'm going to have to whip out the pressure washer and clean some stuff up.
2. Have an 82 blazer with a 3 wire 2 prong "l l" oil pressure sitch plug. And my motor not sure what year it came from like an 84-86 suburban has a 2 prong in block above oil filter. Can i splice the 3 wire to make it work or buy the right sensor to put in block? Have heard that they also put some in back of block behind air cleaner?
3. Also going from a 4 peice oil pan seal to a felpro 1 peice?
You guys ever use the expensive ones, metal dipped in rubber, they work for oil pan?
