How much vaseline? Just smear a thin coat with my finger?
that's more of a personal preference.
Just like you said. Just smear it. Nothing thick or too thin.How much vaseline? Just smear a thin coat with my finger?
Just replace guitar with TH350 and we have a chevy hitIs it just me or does anyone else read the title of this thread and think in their mind, "while my guitar gently"?
Can you link the O ring? I havent been able to source it
No... checkedDoes it leak where the dipstick tube goes into the transmission? Mine does and it makes it look like it's the pan gasket leaking.
Im betting something happenend when installing the tranny mounts, I had to lift the case to slide the mounts out. I bet that lifting messed with the input shaft seal...
highly unlikely.
have you drove it and verified the fluid level yet? That's the first step.
You are supposed to fill up a few quarts and run the engine to fill up the passages and then top off to the proper level.I haven’t even had a chance to even fire it up, to get warm enough to check.
Im guessing I probably added too much fluid on a cold truck. I used a few half-ish bottles to start. So exact amount initially added was a guess
Ok, I drained a bit of fluid 40min ago or so. Just went back out and its dry-ish. I can see faint trace of fluid where as before it was dripping off the pan
It's the only way to not overfill
