Stock type steering correction. You probably should not use what you think.
Discussion in 'The Garage' started by Stephen, Apr 6, 2017.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,719
    983
    Grand Rapids area
    Build(s):
    So if the spring has negative arch, the draglink should slope uphill? The more the front half of the springs slopes, the more angle you should have in the draglink?
  2. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,458
    236
    Brighton Tn
    I'm running the raised steering arm with approx 5" of lift and 35s
    My drag link is at approx 8 deg down and I have no issues with bump steer.
  3. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,871
    96
    Tucson, AZ
    I've got ORD springs and crossover and the bumpsteer is very noticeable. It's not real bad most of the time, but a section of road near here has several "whoops" in it and it's a little disconcerting as it tries to drive off the side of the road. I run no sway bar. It seems like it's just the nature of the beast with soft leaf springs.
  4. Blue85
    Jul 26, 2000
    9,719
    983
    Grand Rapids area
    Build(s):
    Yes, several of us have mentioned this, possibly all with ORD springs. If the PS side travels upward, it changes the distance between the knuckle and the steering box, so how can it not bumpsteer? A panhard bar could help this, but creates other issues. If you have Rough Country springs and crossover, you won't notice bumpsteer because the suspension doesn't move much. After some time you can learn to "let" the steering wheeling move on a bump, but it's still a little weird during turns. Crossover reduces roll-steer a lot, which is the big advantage on the street. Overall more steering control. And we all understand why crossover is better off-road.
    6872xtc likes this.
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,560
    777
    New Hampshire
    Build(s):
    I've been debating in my head for a while if crossover is worth it for my truck. I'm running a 4" Tuff Country EZ Ride lift springs with no sway bar and Bilstein 5100s. It rides decent but could be improved. I have a raised steering arm so the drag link is parallel to the ground. Bump steer in general isn't a problem but I guess that I have roll steer and it definitely veers to the right while braking hard. This truck is definitely more of a street queen now so Would crossover make it more street friendly or should I try a shorter steering arm? Or is this just the nature of the beast? I also don't want to trade one set of problems for another with cross over given the cost of it.
  6. Mastiff
    Jul 21, 2002
    2,871
    96
    Tucson, AZ
    In my case, street driving got noticeably worse with crossover. I did it because it was hugely impacting suspension travel of my suspension, and I could see how under certain off road conditions I would barely be able to steer. Based on my experience, I would not go to crossover for a mostly street rig, or even for one with limited suspension travel where you aren't seeing a problem.
    CrpMag122 likes this.
  7. ktmoutfront
    ktmoutfront Stuck going nowhere fast Premium Member GMOTM Winner
    Feb 20, 2007
    13,127
    6,007
    Would rather be on the road
    Build(s):
    3
    @Chevy305 your pulling during braking is bump steer. As long as it's not in the brakes or tire pressures being way off.
  8. CrpMag122
    CrpMag122 1/2 ton status Premium Member
    Nov 2, 2011
    266
    172
    Northern CA
    For what it's worth, I concur. I went crossover for mine and it has caused all sorts of steering issues. Granted, I am running 37's with a 6" lift and the springs are super soft (ORD springs). The problem with mine is because of the larger sized tires and soft springs, the whole front suspension moves side to side while steering. It's just the nature of the beast when you are running that type of set up. If you planned on doing any off-road driving with it I would suggest going to crossover but for a vehicle that will not be doing much if any off road, I don't really think it will be worth the money and potential other issues that would need to be addressed.
  9. Chevy305
    Jan 23, 2006
    11,560
    777
    New Hampshire
    Build(s):
    Wow for as much people around here praise cross over, I'm kinda surprised/relieved by the responses. I say relieved because now I don't need to spend $1k on parts that I don't need.
    @ktmoutfront I do definitely have bump steer, it is pretty evident on an RTI ramp. Driving on the street, barely noticeable in most normal driving situations.
    campfire likes this.
  10. CrpMag122
    Nov 2, 2011
    266
    172
    Northern CA
    @Blue85 and @Mastiff , have either of you tried hydro assist to see if that helps? I have a redneck ram coming hoping that will help with the side to side movements a bit.
  11. Blue85
    Jul 26, 2000
    9,719
    983
    Grand Rapids area
    Build(s):
    I'm trying to think what happens if you have "stiff" hydro assist and crossover and stuff a tire. Seems like if the wheels continue to point straight the steering wheel would turn in your hands, but I have no idea how to estimate the effect of the hydraulics in that case. Seems like full hydro would completely solve this problem, although it comes with other issues.
    Let's let ORD chime in with experience, or somebody else who has converted many trucks.
  12. ktmoutfront
    Feb 20, 2007
    13,127
    6,007
    Build(s):
    3
    All steering geometry on a straight axle will have some bump steer, except full hydro. On a tall lift or with long travel, crossover will have less than push/pull geometry.
    If spring shift is a big issue, need for checking bushings and such is necessary. A pan hard bar can help some of the shift also.
  13. CrpMag122
    Nov 2, 2011
    266
    172
    Northern CA
    I checked the bushings on mine and the only bushing that has a little bit of flex to it is the top bushing in the FUSH kit I installed. I called ORD and they said this is normal to see with soft springs and big tires. I believe I spoke with @Stephen. He said hydro assist was the best bet as the panhard bar option creates other issues. I know there was another thread I found where Stephen went into detail about said issues.
    Here is that thread.
    https://ck5.com/forums/threads/crossover-and-bumpsteer.324522/page-2
  14. ktmoutfront
    Feb 20, 2007
    13,127
    6,007
    Build(s):
    3
    I can't follow along anymore. That's the thread I thought we were in.
    The thing we all have to remember is, we are not driving Porsches. I bet I had $2k in custom suspension on my lowered 2wd lb road race truck. And I built it all. Still would not beat a 911 at RIR. It would beat most Corvettes back then.
    I straight axle has it limits.
    skunked likes this.
  15. Blue85
    Jul 26, 2000
    9,719
    983
    Grand Rapids area
    Build(s):
    How is there more torque with crossover? Is the pitman arm shorter or the steering arm longer? Some claim to have a better turning radius with crossover, which implies the opposite. Are you just saying that with articulation crossover maintains better leverage on the steering arm? When the DS tire is drooped and the push-pull drag link is at 45 degrees to the frame, it's trying to lift/lower the truck as much as it's trying to steer.
  16. skunked
    skunked in the garage Premium Member GMOTM Winner
    Feb 27, 2013
    10,380
    9,026
    Placer County CA
    Build(s):
    yeah me either, it's really a terrible improvement offroad. I'm going back to push pull.
  17. skunked
    Feb 27, 2013
    10,380
    9,026
    Placer County CA
    Build(s):
    that's because you don't wheel it. If you did, you would understand the need for crossover.
    bmxbryant9, ashman and CrpMag122 like this.
  18. H20 Toie
    H20 Toie 1/2 ton status Premium Member
    Jun 13, 2016
    168
    161
    Valencia California
    Now you guys got me scared
    Haven't even got the axles in yet but have all the parts including cross over.
    will really suck if it ends up being worse than stock :(
  19. skunked
    Feb 27, 2013
    10,380
    9,026
    Placer County CA
    Build(s):
    Aren't you linking the front? You need and want crossover, there is no debate there. I was being sarcastic about removing my crossover, I wouldn't make it 100 yards before I was stuck and couldn't steer on the trail without it.
    However for some that are on leafs, mostly street drive their trucks with an occasional trail cruise the push pull is fine.
  20. H20 Toie
    Jun 13, 2016
    168
    161
    Valencia California
    good i would hate to spend that kind of money on it an not like it
    skunked likes this.
