Just go back and paint that rig white and let me know when it’s ready to pick up.
I’ll be on my way.
I’ll be on my way.
Bent Orange?This build is speaking to me. It is on point. Not sure about that bent orange though.
Bent77, aka your neighbor. He has an issue with Chevy Orange don’t mind him anyway. His brain is foggy from dialing in cam timing on his Camaro and he gets cranky.Bent Orange?![]()
Heck ya! We'll figure something out!Look what I found.
I will be loading up a bunch of stuff for the Tri State Swap Meet the first weekend in February but I will rat hole this for you. I know you are gonna want to do some trading for it.
I'll try to think up something I need.
We might just need them for Rob's K5 and my BurbI have atleast 2 of them skid plates if you need more .
The rear NV4500 covers aren't iron but aluminum. A wood spade eats up aluminum just fine....I couldn't imagine it would even scratch ironI would of never thought you could drill a hole in iron with a spade but for wood, I thought the bit would destroy itself before any progress was made, nice way to save some time/money.![]()
That makes more sense, in the picture it looks like iron to me, but I've seen people cut aluminum with wood bits often, just never a spade bit, still interesting.The rear NV4500 covers aren't iron but aluminum. A wood spade eats up aluminum just fine....I couldn't imagine it would even scratch iron
Yes, I'm definitely aware they can be shifted many different ways but I want it to be as mechanical as possible.....so, cable for me@Larry I am sure you know this but you can also run the OX off air or electric. I have 2 set up on air and bought the kit to set a 3rd up that way. using CO2 tanks as the air source.
I know, I totally wanted something unique like an old straight 6 with modern tech. Total bummer that the engine was a turd and so expensive to rebuild. It just didn’t make sense.Is it weird I was way into the idea of a fuel injected 292 for the sheer freak out factor?
Too bad it was a boat anchor. But then again I’m not sure you would know how to react if we left you behind driving to a trailhead in the mountains. So I guess the fat block was a wise choice.
I had a 73 k5 that had very little rust, mostly at the inner rocker and the top of the rocker so I was working with an old school body shop and they built it all from thick gauge sheet metal and it turned out great and is much stronger.I know, I totally wanted something unique like an old straight 6 with modern tech. Total bummer that the engine was a turd and so expensive to rebuild. It just didn’t make sense.
And now for the rest of the story…..
Well, I couldn’t ignore the rocker panel situation forever as it was holding up progress with Raptor Lining the interior, installing the pedals and steering column. As I mentioned a few posts ago, I would have been so much better off just making my own inner rocker out of a flat panel and added a 1” 90 degree bend to one end. That could have been made out of much thicker material than this Taiwanesium trash. The pieces that I got that were supposed to make up the inner rocker made zero sense how they were to fit together so I did the best I could. The pieces left a pretty big gap right in the middle, which I decided to leave open for ease of cleaning and getting in there to add rust prevention.
I POR15’d every possible thing I could reach. I even had POR15 in the crack of my ass once it was done. That stuff is just as bad as antiseize
The outer rocker fit pretty well for the most part. I welded some tabs on the back side of the rear portion so the rocker would sorta clip in place
In true aftermarket panel fashion, things never fit perfectly, but one little cow lick sticking up wasn’t too bad in the grand scheme of things and was easy to fix
So glad this bullshit was over and the only rust to deal with on the entire truck
Somewhere along the line I also made a removable cover for the NV4500 hole and to plug the old transfercase shifter assembly hole. This is the first time I’ve used an early 4500 with the SM465 style shift tower. I had gotten used to the 4500s with the removeable shift tower that creates a lot of clearance when yanking or poking the transmission where as the earlier style shift tower doesn’t. The panel provides more room for yanking and poking. It also allowed for nutserts to be used for the 465 style shifter boot to screw on to.
So, the plan with the trans tunnel is to use a SM465 boot at the trans tunnel, then build a box over the tunnel for the J&B triple stick shifter a place to mount. I’m basically stealing Carl Sandvik idea that he used in his K5, which works well with the Tuffybox Rob gave me last Christmas. Once the box is secured to the floor I plan to use a NV4500 shifter boot above that so the trans will actually be double booted. Hopefully this will cut down on the dust intrusion like I get into my K10’s twin stick shifter boot.
A 73 with minimal rust is definitely rare! Pretty sure they build 73 to 75s out of prerusted sheetmetalI had a 73 k5 that had very little rust, mostly at the inner rocker and the top of the rocker so I was working with an old school body shop and they built it all from thick gauge sheet metal and it turned out great and is much stronger.
