mtrdrms
Hey guys I am really stuck here. My dam cucv won't start. Any suggestions are welcome. So far I have:
Replaced fuel
Replaced fuel filter
Replaced fuel pump
Replaced glow plugs
Replaced batts
I bled the fuel system at the filter and again at the injectors. I cracked the injectors loose and cranked twice for about 5 seconds. All injector lines were wet but when I put everything back together and cranked it good with new batts, I got nothing. No smoke, no sputter, no nothing - just cranking. I do believe my glow plugs are working. After I replaced them i cycled them a few times and pulled one out to check and it had browned a bit and looked to be getting hot. What else can I do? Do I have a bad injector pump? I am running out of patience and I NEED a truck soon for fire wood.
Andy
Replaced fuel
Replaced fuel pump
Replaced glow plugs
Replaced batts
Andy
). If the fuel is there, you probably have a low compression issue. If not, or if it seems to be minimal, then the pump or it's drive is likely to be the culprit. Occasionally the pump gear key shears off, which of course means no fuel. Even more rarely, friction will cause it to slip and turn the pump a bit. The result is not much fuel as well as randomly timed fuel squirts.
