Grandma is going to have none of that, and Mrs Bent says cars aren’t supposed to go sidewaysSo that’s a no to the N2O?
You are no fun at all. lol.
But sideways was how I learned how to drive...Learn how to drive on dirt to begin with and your ability to control a car goes up a bunch. I mean, who doesn't like getting sideways at 70 on a dirt fire road...Grandma is going to have none of that, and Mrs Bent says cars aren’t supposed to go sideways
I tried some Mobil full synthetic once. Didn't care for it.I had a couple different theories before I posted.
GM crate ZZ4. Fresh synthetic oil
Only ticks and blows by, only when hot
This engine had the beans run out of it before we stuck it in moms SS
One theory was the ring stuck in the piston. Ticking with blowby
The other thing I hasn’t already mentioned but wondered about is the oil. So Wade and I were on the same page. Ticking and blowby because the oil is too thin
That engine was snug. Builder said to use 30W, but that sucker also had 80 psi coldI tried some Mobil full synthetic once. Didn't care for it.
The engine that you built has no problems with Schaeffer's 5W-40 full synthetic diesel spec oil. Been running it since I bought the '72 from you.
It seems like it pegs the 60 psi gauge. I would assume that the cold psi is lower with this oil, but that doesn't bother me.That engine was snug. Builder said to use 30W, but that sucker also had 80 psi cold
What pressure does it run on the 5w40?
Well I wouldn't expect you to work on it today.Haven’t had a chance. I’ll probably dump it and filter it, use it as make up oil in one of these other leaky oil burning bastards until I can get rid of it. I did come up with 4x five quart jugs of regular Valvoline
Given the history of this engine, I’m going to try the heavier oil. Engine has approximately 8k miles on it. The rod and main bearings have already been changed. It donated about 4 seasons as the full time engine at the drag stripWell I wouldn't expect you to work on it today.
If you were to use the EPR, don't save the oil. It thins it out and flushes crap out of the engine.
You apparently have never experienced the stripped drain plug from having someone else do it. I have helped people deal with it, never happened on mine. I have bought a few trucks lately that they don't have the original magnetic drain plug anymore... Hmmm.And this is one of the reasons I don’t change my own oil.
petetruckparts.com
Broke that one. Thanks for the link to replace itI have had really good luck with this one. 1/2" drive breaker bar fits it. Can slide the strap to the base of the filter. Self adjusting and only gets tighter the harder you pull the bar or ratchet. Just clean the strap well if you get oil on it.
FILTER WRENCH / STRAP 63500
petetruckparts.com
Their problem. Not mine. I despise fluid changes with a passion. All of them.You apparently have never experienced the stripped drain plug from having someone else do it. I have helped people deal with it, never happened on mine. I have bought a few trucks lately that they don't have the original magnetic drain plug anymore... Hmmm.
OH, and the oil spilled on the engine and smoking as you drive. I have heard of that!
