MountainmanID
I guess I was referring more to the bigger tires wearing on the chain and putting more stretch on it over a period of decades than if it was running 5" (or more) shorter tires.What does the age of the lift have to do with a driveline clunk? Usually the clunk is in the differential spider gears. Old 10-bolts can have a lot of pinion rotation before the all the slack is out. The chain in the transfer case is only for the front drive. If you have unlocking front hubs and/or the part-time kit is disengaged, a loose chain won't have much affect on anything.
But, what I hadn't considered was what you just said about the chain only effecting the front drive and currently the front drive shaft is off the truck and has been since I bought it. I guess I need to have some one watch the driveshaft whenI shift into gear to see what's making the noise
