not to be a rude but the fact your complaining about under 1/4 tank performance in offroad and decent street driving knowing the limits of a given design is your fault to keep pushing it .
Spectra makes a replacement tank that is FAR inferior to what the OEM offered. I have to modify my driving and fueling habits so I don't have to worry about being stranded an hour from the nearest fuel station, because they didn't replicate what was standard for all EFI trucks made from 1987-1991. On something that is supposed to be a replacement?
It's not tough. Stock fuel tank: run it down to 1/8 tank without worry. Spectra: run it to 1/4 tank and worry. That's an additional 40 miles I lose in range.
And if we want to discuss fuel pump cooling, why would we even consider the Spectra, with it's drain holes and speed bumps for a sump, compared to the GM one that positively keeps fuel surrounding the pump?
Now, if Spectra has changed their design for our trucks, like apparently they did for some car apps, where their response to a complaint was ""GM42 Series tanks are the only tank that has a different pump bowl that never been modified. The GM32-34 & 37 series were the modified for the pump bowl for fuel starvation.", then I'll reevaluate.
Just don't try to suggest to me, or anyone else, that the GM sump pictured, is somehow equaled by the Spectra I'm running in my truck now. If it didn't involve cutting the tank in half to get it in there, welding posts to the bottom of the tank, and dealing with brittle plastic, I would have already done so. I made this swap just as Spectra came out with these tanks, and I took a gamble that their ability to equal OEM was part of why they were highly recommended. Fail.
I'll drop it. If anyone decides to run a newer Spectra for their truck, and posts up pics of something even remotely near effective as the GM sump shown in this thread, bully, Spectra pulled their head out. I've said my piece, I don't like the Spectra design I ended up with, it's caused issues in my mild usage, that's enough for me. It's opinion to like or dislike something, if others feel different, that is up to them. I wish I had pics of my "sump" to prove my point, but I don't. The pics above clearly show what the standard is, I would absolutely argue the Spectra is nowhere near as well designed. After all the back and forth, my only wish is to *equal* factory performance, not have it gold plated. And I don't feel that Spectra did. That's it...just replicate the GM piece, preferably in steel.
