vandelay industries
Where did you get the 1st replacement engine?
So to be clear, you don't bother with adjusting the fuel pressure regulator, you just put in a higher performing pump, and it basically accomplishes the same thing?
Some production rebuild outfit in Spokane, Wa.Where did you get the 1st replacement engine?
So what I do is get a drinking water bottle, poke a hole in the side near the bottom shove it on petcock with the cap end pointed down over the back of the steering box to dump into a bucket. I had a picture but can't atm works good thouThanks for all the info, guys!
Anyone know what size tube fits on the rad petcock valve so I can drain that sucker without a mess?
Welcome backHey guys! It's been 6 years since I did any wrenching. Finally getting to fix my truck! Hoping I remember which end of the wrench to hammer with.
Anyway, I'll save you the drama story (which some of you may remember). But in short: 6 years ago I replaced my engine with a remanned unit that turned out to be bad from the get-go. Due to the timing in my life, I couldn't deal with pursuing the warranty and replacing the engine. Today my new GM TBI engine was delivered. Can't wait to get it installed and get back on the trail! Hope to get this done with enough time to get some snow wheeling in this winter.
350/700/241/D60/14BFF - Detroit/5.13 gearing/38" swamper SS/4" Lift + EZ inch + 1" body lift.
I tore down the TBI unit over the weekend. Need to get into the parts shop to get the rebuild kit and some new injectors.
It mostly depends on how you lift it.I plan to leave the core support. I will use a mini excavator to lift it.
I did it with the dizzy, but not when I used the backhoe.When I've done it, I've listed from two diagonal corners.
I assume I can't do it with the dizzy installed?
