pseudomike
Ok guys, I got a cooling issue that is giving me fits. The motor is a 1991 TBI (jasper reman ~20k mi), cammed (EDL-2102), has a Edelbrock performer TBI intake w/proper chip, stock manifolds new exhaust all the way back. The timing is balls on.
The issue I have is that the temp gage burries out before the thermostat opens...it is definitely way too hot not just a bad gage. I have tried multiple things to alleviate this. Thus far... the radiator is new 4 core copper, new heater core, I have changed the T-stat about 8 times Stant and DELCO all sorts of different heat ranges, new temp sensors both sides of the block (tried both heads), swapped a couple different water pumps currently running an aluminum high flow (yes it is reverse rot). I have not messed with the fan, it is stock, but it is definitely pulling serious air and the shroud is in place. When the T-stat opens the temp drops in like 5 seconds to ~150deg then cylces fine from there. Right now I am running it with a small (1/8") hole drilled in the thermostat to let water by before it opens and it seems to work (doesn't burry gage before opening) though it cycles between 195-220deg with a 195 t-stat. Intuition tells me something is wrong. I have drained and flushed the sytem a couple times and everything looks good. I don't see any air in the coolant or other contamination that would indicate a head gasket or mechanical problem nor is there any coolant in the oil, nor does it seem to burn any. It is not losing coolant, the system definitely holds pressure. I am kinda at hits end with it and my presumption is that there is a mechanical issue of some sort in the block IE craked head, head gasket, incorrect intake gaskets??? If anyone has some ideas shoot them my way. Thanks in advance.
