Hubnut
Is it possible the serpetine belt is installed incorrectly resulting in no coolant flow? Just an observation.
Or just run it without a thermostat at all...at least localized heating would be potentially less.I know on my intake manifold gaskets the back water hole had a small hole in the gasket ( as some kind of restrictor ) not like the front water jacket hole. Does that make sense?
Can anybody tell me why that is like that. Thanks
Tarey
Starting in 1987 when TBI was introduced the intake manifold design was changed and now there is a rear water crossover passage and that passage is connected to another passage that is running from the rear of the intake up to the front of the intake. The 1987 and later gaskets have a metal restrictor plate with a small hole in it to control the amount of water flow. Not sure why GM decided to do that other than possibly trying to keep the throttle blades from "icing" .
The only thing that I can think of..other than thin cylinder walls is that it has incorrect or incorrectly installed intake manifold gaskets. I know marine application gaskets are different, perhaps others are as well.
The 197X -1985ish blocks are good to .040" over.
